car starts to vibrate badly around 45mph - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 23rd, 12, 07:58 AM Thread Starter
3 mths ago I purchased a new set of 15" Cragar SS rims and when they arrived I noticed that they came with the "unilug" lug nuts. Over the past 4 weeks I've had each tire off several different times because I was replacing the entire brake system on the car. Now...when the car reaches 45mph it starts to vibrate pretty bad. This was never an issue prior to me taking these tires off so many times so I'm thinking the problme is with the tire/wheel/unilug somehow.
I have no idea as to the condition of the tie rod ends, ball joints...etc as I've never replaced them but they appear to be fine. Could this vibration be related to those unilugs somehow? If so...what could I do to fix that problem. THanks.
soonerdean is offline
post #2 of 4 (permalink) Old Jun 23rd, 12, 08:39 AM
Danny
Re: car starts to vibrate badly around 45mph
If you don't get the unilug washers in correctly they will vibrate. Jack the car up and spin the tires and see if they are running true. The washers can get on a bind and your wheel might not be tight against hub.
lcmc is offline
post #3 of 4 (permalink) Old Jun 23rd, 12, 09:05 AM
Dean
islanddean's Avatar
Thanks.
1967 Camaro Convertible with a 327, TH350transmission, Edelbrock 1406 600cfm carb, Edelbrock 1721 fuel pump & 2701 intake.
"The true measure of a man is not where he stands in time of comfort and convenience but where he stands in time of challenge and controversy."
MLK
islanddean is offline
post #4 of 4 (permalink) Old Jun 23rd, 12, 05:14 PM
Are these wheels hub centric? If not, you may want to consider installing "hub centric rings" to center the wheel to the hub.
schnide is offline
