rear strut relocation kit - Team Camaro Tech
post #1 of 2 (permalink) Old Jun 29th, 12, 11:26 AM Thread Starter
orlando
my 69 has a rear strut relocation bar welded in the rear and my struts have been moved to the inside of the frame rails rather than strait up and down inside the wheel well....is anyone familiar with this set up and if so, how wide of a wheel can in go with it...i do not want to mini-tub but want a deep dish look. i have a set of 15x8 rallys with about 3-3 1/2 backspace.
o_andujar is offline
post #2 of 2 (permalink) Old Jun 29th, 12, 12:19 PM
Vintage 68's Avatar
Wink Re: rear strut relocation kit
That is a common set-up (available from numerous aftermarket manufactures) used to move the shocks out of the way of larger tires.
As far as 'what fits' - only you can decide that on your vehicle.
You need to take into consideration many points;
* ride height
* suspension travel
* fender lip mod
* rear axle location
* rim dia
* rim offset
* tire dia
* tire ratio
Once you mix and match the above you'll find what the max size(s) that will work with your vehicle.
Best site resource is the "Wheel & Tires" forum - https://www.camaros.net/forums/forumdisplay.php?f=17
Read through the various 'Stickies' and posts for combo's that match your set-up and go from there.
1968 Convertible
Some trucks
Vintage 68 is offline
