Question about Weld Wheels - Team Camaro Tech
post #1 of 2 (permalink) Old Jul 10th, 12, 07:17 PM Thread Starter
Larry
I ran across a killer deal on a complete set of Weld Prostars. I looked around here to see what everyone was running and seems that 4-4.5 backspacing was common with these wheels.
The wheels in question are 15 x 4 with 1.75 backspacing and 15 x 8 with 5.5 backspacing. Do yall think these'll fit on my '69 Camaro without issue? I have a stock width 8.5 rear with stock wheel openings.
Larry
s1lv3r is offline
post #2 of 2 (permalink) Old Jul 10th, 12, 07:48 PM
.gearhead.'s Avatar
Re: Question about Weld Wheels
I ran the same sizes on my '68 for a couple years. The fronts are fine. My rears had a 4.5" back space and that was perfect. The 5.5" back space was too close. I'm not sure if a '69 has the same dimensions. I'm sure someone here can verify.
Then: N/A, 436 ci, Stock Block, Track 1's, Stock Suspension, Ranchos, 3250 lbs... 1.33 60 ft / 9.69 @ 138 mph
Now: Boost...
.gearhead. is offline
