Backspace on 17's - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 17th, 12, 07:57 PM Thread Starter
James
Backspace on 17's
Decided I want 17's and 50 series tires.
What the widest tires I can go and what backspace?
My car sits 2 inches lower than stock.
James
68 Camaro Convertible
M-21 Stroked 381 w/ AFR Alum Heads
12 Bolt 4:11s
Fredsgarage is offline
post #2 of 5 (permalink) Old Sep 21st, 12, 09:48 PM
Re: Backspace on 17's
we have 17x7 3.75 BS w/ 225/45 front
17x8 4.5 BS w/ 255/50
on our 68 with eibach springs in front and hotchkis leafs in back
ML's68 is offline
post #3 of 5 (permalink) Old Sep 21st, 12, 11:52 PM
Rick
check the wheel size thread, 69's can run wider than 67 or 68.
I'm running 245-45 17 in front and 275-40 17 in rear.
most agree 4.75" backspacing with an 8 inch rim in front. I used 5" backspacing because I couldn't get my rim in 4.75. It was only available in 4.5 or 5. I have room for a 1/4 spacer but have not installed one yet. It rubs the frame rails at full lock on the inside but is fine at the fender.
rears are 5.5" backspacing on a 9.5 rim. You should be able to run a 255 with plenty of room. My 275 wide required fender lip rolling, but I wanted the widest I could get without mini-tubbing.
Suspension is lowered front and back with Hotchkis lowering springs.
RickH is offline
post #4 of 5 (permalink) Old Sep 24th, 12, 11:37 AM
Mr. Tibbs
Send a message via AIM to ChevyThunder
I'm running
17" American Racing Torq Thrust II
Front: 17x8 (4.75" backspacing)
Back: 17x9.5 (5.5" backspacing)
BFG g-force KDW 235/45WR17 Front and 275/40WR17 Rear
" Burn rubber not your Soul "
Camaro,Camaro,Camaro,Camaro
ChevyThunder is offline
post #5 of 5 (permalink) Old Sep 24th, 12, 11:52 AM
DjD
DjD's Avatar
Hey James, the 50 series tires will limit you in some brands and widths but as an example a 235/50 17 is about 1" taller and has about 1/2" wider section width than a 235/45 17 tire. It's a lot more common to run 40 or 45 series tires on 17" wheels... You might want to go back to the top of this forum and read the thread showing what guys are running as others have suggested...
...Dennis
DjD is offline
