Difference btw Disc and Non Disc Wheels? - Team Camaro Tech
post #1 of 6 (permalink) Old Oct 17th, 12, 08:55 PM Thread Starter
Charlie
Hey there,
I need to pick up a 14" rally wheel for my spare. My car came stock with front disc brakes and the rears have been converted to disc brakes as well. I see there are ads for disc and non disc brake wheels, but honestly what exactly is the (technical/visual) difference and can they be interchanged or can you only use a disc brake wheel on a disc brake car?
Charlie
Edmonds, WA
1969 Camaro SS Vert LS1 T56
camaromaniac is offline
post #2 of 6 (permalink) Old Oct 17th, 12, 09:27 PM
Tim
Re: Difference btw Disc and Non Disc Wheels?
Charlie,
I'm not a wheel expert, so can't offer specific fitment advice, but the wheels made for factory disc brake applications had greater clearance to allow for the brake calipers. As your car has discs F&R, I'd suggest you would have clearance issues if you tried to use drum brake wheels.
There's a table on the CRG "Wheels" page here: http://www.camaros.org/suspen.shtml#Wheels that indicates which 14" Camaro wheel application codes were for disc brake cars. If you have aftermarket brakes, then try the manufacturer's tech line for advice - most specify minimum 15" wheels, but say that some 14" will fit. Wilwood (and others) offer templates to download, but that is more for checking if your current wheels will allow their big brake kits to fit.
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Sold Clippinger Chevrolet. Raced at Lions in LA.
ZLP955 is offline
post #3 of 6 (permalink) Old Oct 17th, 12, 10:34 PM
parkbrau's Avatar
It all has to do with wheel back spacing. Here is a good link that I pulled from the sticky at the top of this forum:
http://www.earlywheel.com/products.h...ng-information
parkbrau is offline
post #4 of 6 (permalink) Old Oct 17th, 12, 10:49 PM
The 14" disc brake wheel will fit factory front discs and factory front and/or rear drum brakes. The non disc 14" wheel will not fit factory front discs.
I would buy the disc brake wheel for your spare. It should fit your factory front discs, and you can hope it fits your rear discs. You did not say what kind of rear discs you have, but assuming your current 14" rallys fit them, you should be safe.
BPOS is offline
post #5 of 6 (permalink) Old Nov 4th, 12, 08:36 PM Thread Starter
Charlie
While not on the CRG chart (must not be a 1st gen) would a 14 X 7 Rally Wheel with "YW" work as a spare for my front and rear DISC brakes?
Charlie
Edmonds, WA
post #6 of 6 (permalink) Old Nov 4th, 12, 10:09 PM Thread Starter
Charlie
After some additional research, the "YW" Rally Wheel was for a Chevelle which was 14 x 6 with a 0.88 Offset.
I can read "X_" on my Rally Wheels, which I will assume are "XG" Rally Wheels with a 0.50 Offset, but will likely need to scrape some of the paint off to verify the G.
Charlie
Edmonds, WA
