5 x 120 fit? bmw rim - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 22nd, 12, 03:31 PM Thread Starter
Gav
USA69Z's Avatar
ive spotted a set of rims online but only in 5 x 120 and i know a camaro is 5 x 120.7 so will they work ? to suit a bmw i believe...
thanx, Gav
RHD 69' 8 STACK INJECTED 383,FAST ECU, TREMECT56 6 SPEED, ATS ,SPEEDTECH, QA1s, HOTCHKIS, RUSHFORTHS , MOSER POSI 3.7, MAGNAFLOWS, ETC ETC
USA69Z is offline
post #2 of 5 (permalink) Old Oct 23rd, 12, 10:03 AM
Vintage 68's Avatar
Wink Re: 5 x 120 fit? bmw rim
Technically
But guys have been doing it and some-what 'getting away with it' for years ...
The biggest problem is that the BMW rims are not "Hub-Centric" as are the original GM offerings.
So, if you have the proper hub adapter that would actually center the rim properly and then installed the lugs carefully I would imagine you could get them centered enough that the side force(s) applied to the lugs would not over stress them and cause breaking issues - still not ideal for any vehicle you intend to drive at elevated speeds or turn quickly/often with ...
There are numerous adapters available for this application that will allow 120mm to fit the 4.75" circle.
Here is one type - http://www.ezaccessory.com/Wheel_Ada...5-5120r-lo.htm
For the 'peace-of-mind' I would go with adapters or just re-drill the hubs/axles to the 120 pattern, and upgrade the studs, if you intend to use the vehicle for any competition or high speed driving.
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 5 (permalink) Old Oct 23rd, 12, 05:00 PM
Tom P's Avatar
Originally Posted by Vintage 68 View Post
Technically
John, my 2011 F10 (550i) are hubcentric with 72.56mm hubs. I would be more concerned about the lug spacing as mentioned, but with adapters, the BMW wheels could be hub-centric depending on year
67 new build alum. 406 | 69 RS/SS 496 631 HP / 618 TQ | 73 Z28 Survivor 36k miles | 89 IROC Z 2500 miles | 02 SS 35th Anniv. LE 645 miles |11 SS Berger 550HP (1 of 25) | 14 ZL1 6M Recaros
Tom P is offline
post #4 of 5 (permalink) Old Nov 6th, 12, 12:00 AM
Pete
No, no, no, do not use those wheels, it will add stress to your studs and make your car unsafe.
Pete
1968 Camaro
2009 Porsche 911 Carrera S
Pete68 is offline
post #5 of 5 (permalink) Old Nov 6th, 12, 01:36 AM
Tim
X2 on what John said. A lot of 1970's Holden models here share the Chevy stud pattern, but from the 80's they changed to the 120.7mm like the European Opels, BMWs etc.
Many guys found out the hard way that putting late-model wheels on an older car ended in broken wheel studs and ruined cars.
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Sold Clippinger Chevrolet. Raced at Lions in LA.
ZLP955 is offline
