67 Camaro tire size - Team Camaro Tech
post #1 of 7 (permalink) Old Nov 1st, 12, 01:11 PM Thread Starter
Ron
67 Camaro tire size
Hi Guys,
I was wondering if anyone can tell me the biggest tire size is that I can
put on a 15x8 stock rally rim on the rear without any clearance problems.
The car has a 12 bolt rear axle.
Thanks for any info
Ron
wldhors2 is offline
post #2 of 7 (permalink) Old Nov 1st, 12, 02:38 PM
Garth
Re: 67 Camaro tire size
Welcome Ron, "stock 15x8 Rally", I'm guessing a Corvette wheel, as no First Gen Camaro's came with an 8" rim. They had a stamped AZ code by by the valve stem hole and a 4" backspace. The backspace meaurement is critical in determining the biggest tire possible w/o clearance issues.
That said, I have aftermarket 15x8 rally wheels in the rear, 4.5" backspace and 255/60 T/A's. Haven't had it on the road yet, but sure looks like they might rub if I hit a bump hard or have a load of bricks in the trunk !
Let's see what other folks have to say....
Last edited by Garfields Maro; Nov 1st, 12 at 09:09 PM. Reason: clarify, aftermarket rally wheels
Garfields Maro is offline
post #3 of 7 (permalink) Old Nov 1st, 12, 07:20 PM
Randy
I have 15x8 Billet Specialties Street Lite wheels with 4.5" backspace and I have 275/60/15 drag radials, no tire rub at all.
1967 camaro, 327, 9.7 CR, comp cam xs274solid, vortec cylinder heads, edelbrock vortec performer rpm, 750 annular carb, HVH 2" spacer, msd pro billet w/6A box, turbo 350 trans, 3500 stall, 4:10 gears, caltracs suspension, m/t drag radials.
rkmjbad67 is offline
post #4 of 7 (permalink) Old Nov 1st, 12, 09:05 PM
Garth
Randy, if the suspension is compressed....(say you've got a load of gravel in the trunk lol) will the 275 go inside the wheelwell without rubbing on wheel opening ?
post #5 of 7 (permalink) Old Nov 1st, 12, 09:34 PM
Randy
Garth, never had gravel in my trunk, lol I have had this setup for about 6 years and have never rubbed the tire on the wheel opening. I even had one side jacked up doing some suspension work on the front and the quarter panel came down really far and did not touch the tire. I have 8.5 10 bolt out of a 72 nova, stock width, same as early camaro. I also have caltrac split mono springs, caltracs, caltracs rear shocks. My profile has a good pic of my car.
post #6 of 7 (permalink) Old Nov 2nd, 12, 02:37 AM
Michael Gekko
I've got 15x8 wheels with 28.5 x 11.5 Hoosier Quick Time Pros on my '68, used a pair of wheel spacers to prevent rubbing, works pretty well. Car has seen only dragstrip service but those return roads are usually worse than any street in America,lol....no rubbing.
Eleanor's Nemesis is offline
post #7 of 7 (permalink) Old Nov 2nd, 12, 04:38 AM
Ron, I have 15x8 cragar's on rear with 275 x 60 x 15 (mastercraft) no tyre rub I think 4.25 bs (second picture are mickey thompson drag/street g50 on centerlines with 4' b/s ) they rubbed on inside gaurd lip not rolled, tried 295 on the cragar's but rubbed on inside chassis, in australia we are not allowed to go outside the guard, I have about 1' clearance on inside chassis
ID:	30644   Click image for larger version
aussie68cam is offline
