Mini Tub a 69 - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 24th, 13, 12:42 PM Thread Starter
Bob
Mini Tub a 69
What is the biggest tire I can go after minning tubbing a 69. Not sure if there are different types of tubbing but doing a standard tub what tires can I go. The wheel will probably be a 15x10 Weld Pro Star. Thanks!
Ramrodd 69 is offline
post #2 of 2 (permalink) Old Jan 24th, 13, 02:12 PM
Steve69SS396's Avatar
Re: Mini Tub a 69
Tire size will depend on how you are tubbing it along with the intended use for the car. I like to drag race my car so I used a set of tubs from Alston. I also notched the frame and moved the springs in. This allows me to run 29X12" slicks or 29X14.5" Hoosier QTP's.
Steve69SS396 is offline
