Help with wheel backspace - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 17th, 13, 09:52 AM Thread Starter
Chris
I've got a brand new set of 255's that I put on my car.. They rubbed slightly on one side.. The other side cleared by less than a mm. My back rims are warped anyways so I want to replace the rims.. I looked for codes on the rims to see what they were but I can't find a code on them. My guess is they've been painted over a ton of times.
I ended up measuring them and it appears to be a 15x7 with 4in of BS. So I assume I'll be completely fine if I get a rim with 4.5 of BS.. Or a 15x8 with over 5" of BS.. Basically as long as less than 3 inches of rim is infront of the hub.. Since I can't find a 15x8 with any more than 5" of BS (Which would leave me with 3" infront of the hub, which is what I have now) I'll probably stick with 15x7.
Just wanted someone to confirm it for me before I order new rims for the rear.
Measuring from the mounting surface to front of rim.
Measuring from mounting surface to rear of rim.
I've had a few people 'old time' mechanics see my car without the center caps on and mention that center looks 'too far out' and I need to move the rim in about half an inch.
I should mention it's a 69 with the full Hotchkis TVS kit. I had the 255's on no problem before I lowered it. Now it rubs on bumps or 'spirited' driving.
SunnyZ28 is offline
post #2 of 5 (permalink) Old Feb 17th, 13, 05:31 PM
Mikael
Re: Help with wheel backspace
I cant see where the piece of wood is in contact with the rim, but for me it looks as you are measuring the outer width of the rim. That should be approx 1" more than the real rim width. So your rim might be 6" wide with a backspace of 4" which gives an offset of +12.7 mm.
The correct offset on my -67 is +6 mm for the rear tires to get them located in the middle of the wheel weels. That is if you have the original drum brakes.
I guess your tires are rubbing on the inside?
Rgds/Mikael
69 Chevelle Malibu 400/TH400 (136379Z328013)
67 Camaro Coupe 327 - Sold 26:th of Aug 2014
Elmer is offline
post #3 of 5 (permalink) Old Feb 17th, 13, 08:15 PM
Allen
Chris, I have 15x8 with 5" backspace and 275x60/15 on the rear of my 69. I have the 1 1/2" lowered springs on rear and my tire rubs on the inside when I corner hard.
69 X-11 RS Conv. Deluxe Int, PW, PT.
69 X-11, Column shift, 350, 12 bolt 4:11, Yenko Clone
68 SS clone, tach, console gauges, 355 with 700R4
67 RS/SS clone, BB, Auto, 12 bolt 4:11
racin67cam is offline
post #4 of 5 (permalink) Old Feb 18th, 13, 01:07 PM Thread Starter
Chris
Rgds/Mikael
Nope outside rubbing actually. It's sitting on the inside of the lip on the rim. It's a 15x7 on the rear, 15x6 on the front. I have no idea what these rims are off (the identification codes are long gone). It's a disc/disc car. I have a TON of room on the inside of the wheel well (probably 2-2.5 inches) but the rim is out too far by about half an inch.
Really? That should in theory be the same setup as I have (3 inches of rim infront of the hub) although a wider tire.. and mine rubs just slightly. on bumps and hard cornering... but mine rubs on the outside.
SunnyZ28 is offline
post #5 of 5 (permalink) Old Feb 20th, 13, 02:15 PM
Allen
Your disc brakes on the rear may be placing the wheel further out than mine.Click image for larger version
ID:	32395 Here is a picture of mine. The rims are 8x15 with 5" bs and 275/60x15 tires, no problem with rubbing outer rear wheel well.
