67 section width and clearance - Team Camaro Tech
post #1 of 8 (permalink) Old Mar 6th, 13, 10:20 AM Thread Starter
Bob
I have read many posts but most are on wheel back spacing.The only thing about tire clearance is about the tire rubbing on something.
I used TA 265/50x15's (10.8 sec. width) in the 70's, but they are no longer available, and they used to rub on something.
Have a 67 that has 11 1/4" between inner fenderwell and inner lip on outer fenderwell. I have read that some have used 275's with a sec. width of 11", but even with rolling the outer wheelwell lip 1/2" this would only allow a tire to wheelwell clearance of 3/8", give or take.
I am not trying to imply that an 11" sec. width would not fit but that the clearance is not sufficient.
A 255 with a sec. width of 10.2" would give a clearance of 3/4", give or take. This sounds to me to be more reasonable for driving on the street.
Or am I wrong, if so , what say you?
Am inquiring about the rear fenderwells.
Big Iron is offline
post #2 of 8 (permalink) Old Mar 7th, 13, 09:49 PM
Garth
Re: 67 section width and clearance
I hear ya. I think the key to running 275's in a stock wheel house is having the rear end up with stiff suspension, as they'll surely rub otherwise. Back in the 80's, I ran 275/50's on a 67 with air shocks. Never again.
Presently have 255/60's, 4.5" BS on my 68, 4 leaf stock suspension. Haven't had it on the road yet, but it looks to be awful close to rubbing the fender lip.
Garfields Maro is offline
post #3 of 8 (permalink) Old Mar 8th, 13, 02:06 PM
Brent
67Rally's Avatar
I run a 275/40/18 on my rear with no issues. No mini tub, no fender rolling. Hotchkis 1.5" drop leafs w/Bilstein shocks.
67Rally is offline
post #4 of 8 (permalink) Old Mar 9th, 13, 05:37 PM Thread Starter
Bob
Brent,
What is the section width on your 275/40x18's?
Big Iron is offline
post #5 of 8 (permalink) Old Mar 9th, 13, 05:42 PM
Randy
I have 275/60/15 drag radials on 15x8 wheels with 4.5"BS, have never rubbed on the inside or outside, stock width rearend, calvert split mono springs, caltracs bars and rear shocks. Rearend is out of 72 nova, same width as the early camaro.
1967 camaro, 327, 9.7 CR, comp cam xs274solid, vortec cylinder heads, edelbrock vortec performer rpm, 750 annular carb, HVH 2" spacer, msd pro billet w/6A box, turbo 350 trans, 3500 stall, 4:10 gears, caltracs suspension, m/t drag radials.
rkmjbad67 is offline
post #6 of 8 (permalink) Old Mar 10th, 13, 05:43 AM
Rick
Camaro67_rcl's Avatar
Send a message via Yahoo to Camaro67_rcl
http://www.rims4less.com/proddetail....2e7e0214bef7d9
Rick
67 RS/SS 355, Autogear M21 (w/Overdrive), 8.5w/3.42
Camaro67_rcl is offline
post #7 of 8 (permalink) Old Mar 10th, 13, 05:52 AM
Brent
67Rally's Avatar
Originally Posted by Big Iron View Post
Brent,
11.06"
Nitto 555's.
67Rally is offline
post #8 of 8 (permalink) Old Mar 10th, 13, 06:58 AM
275/60/15's and never an issue...now the 285/60/15 SH's were very tight and rubbed the inner fender on hard turns and off-camber bumps.
68 Camaro~LSx ~all motor
