17x9.5 backspacing - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 17th, 13, 05:39 PM Thread Starter
Question 17x9.5 backspacing
I know a 5.5 is optimal..but I ran across a brand new set of 17x9.5 rims with +32mm offset..which I believe breaks down to a 6.5in backspace. Would these work on the back of a 69? Maybe with spacers? They are cheap enough I'm thinking about buying em just to resell them..be nice if they would work and not be tucked in to far..
NE1469? is offline
post #2 of 4 (permalink) Old Mar 17th, 13, 05:59 PM
Steiner
Re: 17x9.5 backspacing
6.5" will hit the inner wheel well before it even bolts on. 5.5" actually touches in some situations.
1" is a little much for a standard spacer. You'd have to get those billet spacer deals that cost near as much as a wheel.
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 4 (permalink) Old Mar 31st, 13, 07:21 AM
350camaross's Avatar
I have 17" x8 Boyd Cottington smoothies on the rear of my 69,and the back spacing is 4.5.If i make sharp turns,or on very un-even terrain,i can hear a slight rub on the rear tires.I checked the outer sidewalls for scrapes,but there were none,The rubbing seems to be coming from the inside sidewall of the tire.In my opinion i wouldn't go bigger than a 4.5 offset.
Name:	rear wheel.jpg
350camaross is offline
post #4 of 4 (permalink) Old Mar 31st, 13, 08:09 AM
DjD
DjD's Avatar
A +6 offset is optimal on a '69 so no matter what width wheel you use you can fit the widest tire by using the backspacing that equals +6. This holds true for 15x7" rally's w/ 4.25"bs (factory 15" Z/28) to 17x9.5 w/5.5"bs...
See the chart, find your wheel width and +6 to see what bs to get...
A 17x9.5" w/6.5"bs would require a 1" wheel adapter and that would most likely offset the cost savings of the wheel itself. A spacer is placed over the studs and sits between the hub and wheel, an adapter is much safer and bolts to the studs on the hub and has a second set of studs the wheel bolts to.
...Dennis
DjD is offline
