Measuring wheel studs. - Team Camaro Tech
post #1 of 10 (permalink) Old Mar 19th, 13, 08:56 AM Thread Starter
steve
This may be a stupid question and I never had a problem ordering wheel studs before but I just had my 2nd set come in wrong.
I know you can mesure the knerl size with a wrench but forgot how and can not seem to find the info chart.
Does anyone have the american standard wrench to knerl size chart?
chevnut55 is offline
post #2 of 10 (permalink) Old Mar 19th, 13, 02:39 PM
Re: Measuring wheel studs.
I think you're best off measuring the knurl with a caliper. You might get lucky and find an open end wrench that works, but more likely than not you'll have something that's a tweener. I have this el cheapo HF digital caliper on my pegboard and I use it all of the time for stuff like that - http://www.harborfreight.com/6-inch-...per-93293.html
BPOS is offline
post #3 of 10 (permalink) Old Mar 19th, 13, 02:45 PM
7/16 x 20 is the thread size and I know .480 was tight.
68 Camaro~LSx ~all motor
post #4 of 10 (permalink) Old Mar 19th, 13, 04:43 PM Thread Starter
steve
Thanks,
I tryed .486 but they were too small.
I need to oder the correct studs tonight.
The front is a 69 drum hub and the rear is a 73 nova .
Every place I check has 3 different sizes, but what is confusing is I quess every bolt company measures different.
I am going with 1/2 "x 20 ARP .
I am thinking of just going with screw in, but I am not shure how hard the thick steel is to drill and tap.
I have a good kit but do not feel like breaking taps and bits trying.
Its not a race car but I figure if Im going to chang them do it now.
post #5 of 10 (permalink) Old Mar 19th, 13, 04:58 PM
Andrew
Andrew69's Avatar
They are probably 7/16 fine threads with a knurl of a larger diameter. If you carry one to your local auto parts store they can probably measure it for you.
Skunk Works
Some photos:
Member # 159
Andrew69 is online now
post #6 of 10 (permalink) Old Mar 19th, 13, 05:31 PM
Drill and tap is going to be a pain to keep them straight.
Take an old one that fits and go to the parts counter and ask to see their Doorman box for studs. They should have a good selection.
post #7 of 10 (permalink) Old Mar 20th, 13, 06:18 AM
Moroso or ARP studs, they seem to fit tighter. The shank serrations seem to be deeper.
TC # 349
zdld17 is offline
post #8 of 10 (permalink) Old Mar 20th, 13, 06:24 AM
Jeff
yellow69RS's Avatar
Dorman had a illustrated book when I was in auto parts. and a listing by size. I always went that way when I needed one different then stock. Good Luck finding one of those books today.
Jeff
yellow69RS is offline
post #9 of 10 (permalink) Old Mar 21st, 13, 06:44 AM Thread Starter
steve
After driving my hub around all day I found a parts store who had a measuring gauge who knew how to work it and cared enough measured it at .566 .
I just orderd 10 .568 arp . now I hope the rears are the same as the front.
post #10 of 10 (permalink) Old Mar 21st, 13, 02:18 PM
.566 ???? not stock for sure. Thats over 1/2" Whats these in again ?
