68 camaro wheel size - Team Camaro Tech
post #1 of 8 (permalink) Old Mar 29th, 13, 08:05 AM Thread Starter
danny
Hi my names danny im new here im working on building a 68 camaro and i have a 9 inch thats narrowed 4 inches and im not mini tubing my car and i was wondering what wheel and tire size i can run with 18 inch wheels im kinda going for the deep lip look i wanna get it as deep as possible with the narrowed rear without mini tubing the car
dannyz68 is offline
post #2 of 8 (permalink) Old Mar 29th, 13, 08:33 AM
DjD
DjD's Avatar
Re: 68 camaro wheel size
Let's assume your car is going to sit a bit lower than stock or at least not have the rear end jacked up 70's style... From there a 275/40/17 or 275/35/18 tire is about as wide as you'll fit without a mini-tub. With a factory rear end, a 9.5" wheel with+6 offset (5.5" backspacing) centers the wheel and tire about as good as it gets. You need to figure the difference in your narrowed 9" and adjust the offset (backspacing) to account for the difference.
...Dennis
DjD is offline
post #3 of 8 (permalink) Old Mar 29th, 13, 08:37 AM
Ty
69&76's Avatar
Not the exact application as your 68 but I have a 69 with 10 bolt rear end. It is lowered 3.5 inches. I am running 18x9.5 with 5.5 back spacing. I had to shave off about 1/4 inch of the fender lips.
With your shortened rear end you can probably run 10 wheels.
With my set up I had to modified my shock mounts as they were rubbing on the inner wheel.
69&76 is offline
post #4 of 8 (permalink) Old Mar 29th, 13, 08:41 AM
DjD
DjD's Avatar
A shortened rear isn't going to allow more room between the fender lip and inner area of the wheel well...
...Dennis
DjD is offline
post #5 of 8 (permalink) Old Mar 29th, 13, 04:01 PM Thread Starter
danny
thank for the reply dennis and ty thanks for the pics i really like your car thats about the same style of wheel im wantin to run i think i probably should run the 9.5 wide wheel just unsure on the backspacing with my rear end being narrowed 2 inches on each side i was hoping to get more of the deep look with it being narrowed i figure i should be able to fit a nice deep lip wheel that way
dannyz68 is offline
post #6 of 8 (permalink) Old Mar 29th, 13, 04:04 PM Thread Starter
danny
sorry also im unsure of lowering the car yet eventually i would like to lower it a bit in the rear just tryin to piece together what would be the best set up i really like the lowered look i just wanna make sure i get it all right the first time so im happy with the look i achieve
dannyz68 is offline
post #7 of 8 (permalink) Old Mar 29th, 13, 05:47 PM
Mule
danny, there is a great wheel and tire thread under the fourm tab. Lots of pics and specs on wheels, tires and mods.
Mule
Buckets and piles of a 1968 SS Conv 396
-piles are getting smaller, and it started !
- got the paint on, interior is next.
- interior is about done, it's cruise'able !
- down to top,windows and a few little pieces and it's done
Muletime is offline
post #8 of 8 (permalink) Old Apr 1st, 13, 06:05 PM Thread Starter
danny
Thanx ill check it out n c what I caint come up with
dannyz68 is offline
