Tire Recommendation - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 4th, 13, 06:03 PM Thread Starter
Tire Recommendation
I'm looking for a tire size that will give me the most foot print or grip for cornering.
My rims are steel and 15x7 4.25 all four.
My tire of choice are bfg's.
Any suggestions will be much appreciated.
ra11eysport is offline
post #2 of 4 (permalink) Old Apr 4th, 13, 06:50 PM
Matt
Re: Tire Recommendation
David,I have the exact same rim size as you on all four corners. I am running BFG 245 60 R15 radial Ta's.The overall tire diameter is 26.6" and the contact patch is about 8.5''. They don't rub and are the same size on all four corners,which is nice so that I can rotate them as I need to. The car handles very well and the tires grip the road well, even in heavy rain. I would recommend them. There are not many choices out there for 15'' tires. I have alway run BFG's on all of my camaro's without any negative experiences.
12 Bolt 3.55 Posi
461 BBC TKO600
Matt 69 is offline
post #3 of 4 (permalink) Old Apr 4th, 13, 07:30 PM Thread Starter
Great thanks, the tires I have which I forgot to mention are 225/60 so I'm not too far off.
post #4 of 4 (permalink) Old Apr 8th, 13, 12:08 AM
Pete
I had 235/60-15's back in the early 90's on mine and it worked well. Prob is 15" tires kinda suck cause nobody makes a high performance sticky 15" tire. But if you want to keep it old school...
Pete
1968 Camaro
2009 Porsche 911 Carrera S
Pete68 is offline
