20/18 Wheel Tire Combo fitment - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 9th, 13, 08:56 AM Thread Starter
Carl
Been lurking often since I got my car almost a year ago, learning tons!
Looking for some fitment input on the direction Im considering for wheels/tires.
I currently have 15x7 ralleyes, 255/65/15 rear, 235/60/15 front
Im very happy with my current stance. I have a Hotchkis drop spring in front, original (sagging?) multi-leaf in rear.
Very slight rubbing on front with sub-frame at full lock.
Im just finishing up my 4 wheel drum to disc conversion (Right Stuff from Matts) and havent mounted my wheels again or driven the car yet.
Thinking of going with a 20 rear/18 front combo (dont need to hear the commentary on considering that choice I know not all on here like that direction).
Looking at MB Old School wheels
Rear: 255/35/20 on 20x8.5 +7 offset (5 backspace, right?)
Front 225/40/18 on 18x7 0 offset (4 backspace, right?)
These tires are about 1 less diameter than my current on both ends, which should keep my stance and drop my car by .
Concerns:
225/40/18 on 18x7 from what I can see 7.5 is the recommended minimum width. Will this look goofy? Will it void any warranty?
Rubbing on front ultimately Im going with a smaller tire, so think Im okay but not totally sure how to correctly measure my ralleye backspace to compare confidently. Also wondering if my disc package has pushed out the wheels too much if my wheels push out it appears I need to worry about rubbing on the lower rear of the fender opening, no?
Is there anything Im not thinking of??
Appreciate any input/experiences.
69 LM1 RS Vert White/Red GM Canada documented
69RSRAG is offline
post #2 of 4 (permalink) Old Apr 11th, 13, 09:18 AM Thread Starter
Carl
Re: 20/18 Wheel Tire Combo fitment
TTT
Anyone? Any input?
100 views... no responses...
69RSRAG is offline
post #3 of 4 (permalink) Old Apr 15th, 13, 10:39 AM
Brent
67Rally's Avatar
You probably won't get many comments since there are very few if any people running 20's here.
I think the 225's will be fine on a 7" rim. They will bulge a little more than on a 7.5" rim, but it won't look goofy. I would probably run 255/40's in the rear. The 35's are going to look like a rubber band especially on a 20" wheel.
Your backspacing should be good on those.
67Rally is offline
post #4 of 4 (permalink) Old Apr 16th, 13, 08:09 AM Thread Starter
Carl
Thanks Brent, I appreciate the input.
Checked out your photos and build thread - nice stuff!
Hope you're doing okay in Boston... what a shame...
69RSRAG is offline
