Will this size fit the front - Team Camaro Tech
post #1 of 7 (permalink) Old May 3rd, 13, 10:21 AM Thread Starter
Can you run 205 70 R 15 with 4.5 back spacing on the front of a 68 Camaro, stock suspension, with out rubbing ?
meusebi is offline
post #2 of 7 (permalink) Old May 4th, 13, 02:28 AM Thread Starter
Re: Will this size fit the front
Does anyone run this combination ?
meusebi is offline
post #3 of 7 (permalink) Old May 22nd, 13, 06:42 AM Thread Starter
For future reference 4.5 backspace wheels will not fit a 68 Camaro, the rim will rub on the tie rod knuckle.
meusebi is offline
post #4 of 7 (permalink) Old May 22nd, 13, 02:02 PM
69-Pace's Avatar
Sorry you had to go it alone on this thread.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #5 of 7 (permalink) Old May 26th, 13, 02:51 AM Thread Starter
No problem if it helps someone in the future it will be great. I did put spacer in and it works fine, although I don.t like spacers. I have heard but will need to confirm if I go to disc brakes they will sit out a little further and maybe I can eliminate the spacers.
meusebi is offline
post #6 of 7 (permalink) Old May 26th, 13, 03:11 AM
Garth
Yes, FDB will move the wheel out 1/4-3/8 ", depending on the manufacturer. I have 4.25 BS, 215/65 15 with stock suspension and DB, with no issues.
Garfields Maro is online now
post #7 of 7 (permalink) Old May 26th, 13, 05:55 AM
kevin
I have the same thing with no problem
flat tire is offline
