15" Wheels for Dog Dish Hub Caps & Stock Type Disc Brakes - '68 Camaro - Team Camaro Tech
post #1 of 12 (permalink) Old May 14th, 13, 09:23 AM Thread Starter
Apprentice
Wes
Looking for a set of wheels for a 1968 Camaro with dog dish hub caps. I eventually plan to upgrade the car with stock type 4 wheel disc brakes.
I have just a couple questions:
1. I emailed Pete Pausen asking whether or not they make a wheel that will fit the dog dish cap and clear disc brakes. They responded that they make a wheel that accepts a 10 1/8" hub cap. They did not address my question about disc brakes.
I'm currently down range and unable to measure the hub caps. Can someone confirm whether or not the hub caps have a 10 1/8" diameter?
2. I did a search and couldn't find anyone running 215 70R 15 tires on all four wheels. Will this tire clear with stock height 6308 Moog front and stock height leaf springs in the rear?
TIA
Wes
1968 Camaro (My son's)
1967 Chevy SWB Fleetside
1962 Corvette
1957 Chevy 150 2 Dr Sedan
wesmigletz is offline
post #2 of 12 (permalink) Old May 14th, 13, 01:41 PM
Kevin
sleepsinshed's Avatar
Re: 15" Wheels for Dog Dish Hub Caps & Stock Type Disc Brakes - '68 Ca
I'll take some measurements when I get home. I picked up some 15x7" steel wheels at a flea market a few years ago to use with the dog dish hubcaps, and paid $75 for the set. You might want to check some junkyards for the wheels.
That tire size shouldn't have any clearance issues.
Kevin
sleepsinshed is offline
post #3 of 12 (permalink) Old May 14th, 13, 04:27 PM
Kevin
Looks like they will fit.
Some wheel pics for reference:
Kevin
post #4 of 12 (permalink) Old May 15th, 13, 12:05 AM Thread Starter
Apprentice
Wes
Kevin, thanks for the pics. You wouldn't happen to know what GM application might have the 15 X 7 wheels with the nubs, or will I likely need to go aftermarket?
1962 Corvette
post #5 of 12 (permalink) Old May 15th, 13, 07:20 AM
Kevin
I think pretty much every GM stock steel wheel from the 60's and 70's will accommodate the small hubcap. The wheels I got likely came from a full-size Chevy, like a Caprice or Impala. I have a number of other steel wheels from that era that the dog dish hubcaps will fit on as well. This type of wheel should be easy to find in a junkyard or flea market.
Kevin
post #6 of 12 (permalink) Old May 15th, 13, 09:48 PM Thread Starter
Apprentice
Wes
Thanks Kevin, hopefully I can find a set in Pomona, or figure out a vehicle application. Then I can look for a set on craigslist.
1962 Corvette
post #7 of 12 (permalink) Old May 16th, 13, 05:25 AM
Brent
Brentmc's Avatar
Wes,
I I just PM'd you with the wheel codes and cars that have those wheels--the codes are by the valve stem and will fit what you want.
I have a set of them on my 68 in my signature as you see below.
They are sometimes found at swap meets, craigslist, etc. I paid around $120 for a clean set of 4
Brent
1968 RS/SS Lemans Blue
Brentmc is offline
post #8 of 12 (permalink) Old May 16th, 13, 05:29 AM
Brent
Brentmc's Avatar
duplicate post
Brentmc is offline
post #9 of 12 (permalink) Old May 17th, 13, 11:10 AM Thread Starter
Apprentice
Wes
Brent, thank you. Got the PMs, but was unable to reply because your mailbox is full.
Having the vehicle applications will make the search that much easier.
1962 Corvette
post #10 of 12 (permalink) Old May 17th, 13, 11:57 AM
George
Wes,
I'm going 215/65R15s on my heap on 15x7 rally wheels
George Kettler
US ARMY Retired
o 70 Elky SOLD 9/2016
o 68 Vette 427, 4 spd ac owner 25 years
o 68 Camaro Rallye Green Vert 327/2004R/3.73
kettbo is offline
post #11 of 12 (permalink) Old May 17th, 13, 12:37 PM Thread Starter
Apprentice
Wes
George, the 215 65R 15 seems like a popular size. I was leaning toward the 215 70 R 15 tires, because I liked how they rode on our Chevelle, not against the shorter 65 series tire. It will probably come down to what we can find with raised white letters and the cost.
I look forward to seeing your car when I get back. Reb will probably be with me from mid-July until he has to go back to school.
1962 Corvette
post #12 of 12 (permalink) Old May 20th, 13, 08:52 AM
Brent
Brentmc's Avatar
Fwiw, I have 235/60/15 on my car pictured above--that's all I could stuff under the front and it still rubs when I turn to full lock when turning around...
Brentmc is offline
Tags
215 70r 15, dog dish, wheels and tires
