69 Camaro frt wheel and tire options(rubbing) - Team Camaro Tech
post #1 of 4 (permalink) Old May 22nd, 13, 08:38 AM Thread Starter
Jeremy
Unhappy 69 Camaro frt wheel and tire options(rubbing)
I just added disc brakes to the frt of my 69 and now my tire or tires are rubbing on the fender. I have 225/50/17's on the frt with a 17X7 and a 4 in bs. It did not rub at all with the drum brakes... not even close. However with the disc brake setup, they say it moves the offset out 3/8" i didn't think that would add much but it does... My rear tire is a 255/50/17 and these frt tires offset the rear perfectly as far as height. I know my options are
a: get a 4.25 in backspacing wheel
b: trim the fender lip a bit on a restored Camaro
c: get a different sized tire
I like option C the best, but I am not sure what tire I could run on the frt without it looking stupid, or keep it from rubbing. My 225/50 sure isn't wide...
69 Camaro Finally restored. New 496, 700R4, 3200 stall, 3.90 12 bolt posi
LYK2ROC is offline
post #2 of 4 (permalink) Old May 22nd, 13, 09:27 AM
Steiner
Re: 69 Camaro frt wheel and tire options(rubbing)
I'd look for some 4.25-4.5 backspace wheels or first have 0.5 degree negative camber put on it to see if that helps. If you take it to a shop and ask them to align it they'll do stock specs which is positive camber and tips the top of the tire out a little. I think you're going to be stuck looking for another wheel though... Even the old 7" rims with narrow (by today's standards) bias ply tires had 4.25" backspace.
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 4 (permalink) Old May 23rd, 13, 04:12 PM Thread Starter
Jeremy
Unfortunately I think you are right... i know I have heard people having troubles running these, but they fit my car perfect... with drum brakes that is... I will have a nice pair of 17X7 in American Racing Hopsters for sale...OR.. i could possibly run my rears up frt and get some 17X9.5's for the rear... but i think i would have to get new rear tires for those wheels.. Jeez.. i can't catch a break...
LYK2ROC is offline
post #4 of 4 (permalink) Old May 23rd, 13, 04:43 PM
Kumar
Originally Posted by LYK2ROC View Post
I have 225/50/17's on the frt with a 17X7 and a 4 in bs. My rear tire is a 255/50/17 and these frt tires offset the rear perfectly as far as height.
this is the exact set up I just put on mine yesterday....not sure if i'm gonna rub yet, weather here has sucked for a few days
1969 RS/SS, rust free X-11 car, ZZ430 GMPP Crate Engine, Tremec TKO 600 5 speed Hurst Driveline conversion, Moser 12 bolt/3:73 posi
bigarmzz is offline
