1969 Camaro SS - slight tire rub - Team Camaro Tech
post #1 of 14 (permalink) Old Aug 6th, 13, 02:44 PM Thread Starter
Matt
I have a 1969 Camaro SS that has BF Goodrich Radial T/A, 225/60R15, on a 15"x7" Cragar SS rim. On occasion, I experience some tire rub on the front passenger side tire when hitting a large bump, a dip in the road, or I have a larger passenger in the car. I replaced the front springs, as the right one was weak and that helped out a great deal, but still rubs every now and then. I was going to replace the front shocks with a much stronger spring shock, but am having trouble finding a shock that will fit through the hole in the lower control arm. No rub at all on the driver side. Frame on car is pretty straight and the car sits level. Any feedback would be greatly appreciated.
Matt69SS is offline
post #2 of 14 (permalink) Old Aug 6th, 13, 02:49 PM
Shane
Re: 1969 Camaro SS - slight tire rub
I think if you want a coil plus shock you will need to remove the coils spring and go with something like this
http://www.qa1.net/qa1_motorsports/d...djustable.html
Ive been mulling it over lately.
Or you need to change out to a stiffer coil spring. When I did my front end last year I went with the 6308 springs. They are too low and to soft for my taste.
stea is offline
post #3 of 14 (permalink) Old Aug 6th, 13, 06:20 PM Thread Starter
Matt
Thanks. I have been looking at something similar, but didn't really want to spend that kind of dough, but looks like I might have to.
Matt69SS is offline
post #4 of 14 (permalink) Old Aug 7th, 13, 02:55 AM
Using a 7 inch wheel is the risk involved. How much is the rub?
Compare the distance from the drvr side to the top of the tire with the pass side, same spot.
If you add a 1/8 inch shim to each upper control arm bolt, would this pull in the top?
Is the front metal towards the drvr side a touch?
post #5 of 14 (permalink) Old Aug 7th, 13, 04:40 AM
Bruce
Where is it rubbing? It could be the bolt at the top of the wheel well molding, the inner fender?
The Camaro Guy is offline
post #6 of 14 (permalink) Old Aug 7th, 13, 03:44 PM Thread Starter
Matt
It is a very slight rub only when I drive over a dip in the road. There is about a 1/2" difference between the gap on the drivers side and the passenger side. It isn't damaging the tire at all, just annoying every now and then.
Matt69SS is offline
post #7 of 14 (permalink) Old Aug 7th, 13, 03:44 PM Thread Starter
Matt
The bolt has been removed. It is rubbing on the fender well trim.
Matt69SS is offline
post #8 of 14 (permalink) Old Aug 8th, 13, 04:20 AM
Bruce
How about if you took a rubber hammer and tapped the area slightly?
post #9 of 14 (permalink) Old Aug 8th, 13, 04:33 AM
68resto's Avatar
I had the EXACT same symptoms with the same size rim on my daily driver (130 miles a day). I switched to 215/60/15 and the problem is gone. I couldn't believe that it made that much of a difference. There was no stance or look change. The tires were the cheapest thing to replace compared to the other solutions.
68 Cloned RS/SS w/ all the goodies.
67 Firebird w/ a Chevy 350
67 Camaro 6 cyl. 68,000 original miles
w/ wife & kids w/ the same addiction.
68resto is offline
post #10 of 14 (permalink) Old Aug 8th, 13, 06:34 PM Thread Starter
Matt
Was it rubbing on both sides in your situation or just the passengers side like mine?
Matt69SS is offline
post #11 of 14 (permalink) Old Aug 9th, 13, 04:42 AM
Bruce
Mine rubbed on the pass side and I tapped it with a rubber hammer. . . .gently and there is no more rubbing.
post #12 of 14 (permalink) Old Aug 9th, 13, 10:00 AM
68resto's Avatar
Just the passenger side. I actually laughed when I read your post so I know how annoying it is.
68resto is offline
post #13 of 14 (permalink) Old Aug 9th, 13, 12:18 PM Thread Starter
Matt
Thanks for the feedback guys. I really appreciate it.
Matt69SS is offline
post #14 of 14 (permalink) Old Aug 10th, 13, 06:57 AM
George
Gbauer's Avatar
Mine rubbed a bit more on the inner fender. An 8 lb fine-tuner did the job just fine...
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
