18 x 8" Front Backspacing - Team Camaro Tech
post #1 of 13 (permalink) Old Aug 22nd, 13, 12:50 PM Thread Starter
James
Question 18 x 8" Front Backspacing
Good afternoon! I came accross a sweet deal on some 18" TTIIs for my '69, but was curious if the backspacing will work. The front rims are 18 x 8" with 4.5" backspacing. I have read that anything from 4.5" to 5" will work. Is there any concern with 4.5" backspacing?
Thanks!
James
CamaroMan469 is offline
post #2 of 13 (permalink) Old Aug 23rd, 13, 01:24 PM Thread Starter
James
Re: 18 x 8" Front Backspacing
Anyone?
post #3 of 13 (permalink) Old Aug 23rd, 13, 02:13 PM
Skip
Skeeter55's Avatar
Sounds good to me, but maybe some more info like disc or drums, and is it lowered, what size tires?
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #4 of 13 (permalink) Old Aug 23rd, 13, 02:15 PM
Ty
69&76's Avatar
That is what I have on my 69 with disc brakes on the front. Fits fine. My rears are 18x9.5 with 5.5 B/S.
69&76 is offline
post #5 of 13 (permalink) Old Aug 23rd, 13, 05:26 PM Thread Starter
James
It has disc brakes on the front and its lowered with Hotchkis 2" front springs and 1.5" rear leafs. The front tires will be 245/40/18.
post #6 of 13 (permalink) Old Aug 23rd, 13, 05:53 PM Thread Starter
James
Do you ever get any rubbing? Even when you turn from lock to lock?
post #7 of 13 (permalink) Old Aug 24th, 13, 01:58 PM Thread Starter
James
Anyone else?
I had my local tire shop "measure" today and they said 4.5" would be perfect, but it was a quick and dirty measurement.
My front disc brakes are a cheap imported conversion kit, not a really nice Wilwood or Baer setup. That makes me think that they aren't as thick as the quality replacement calipers. What do you guys think?
post #8 of 13 (permalink) Old Aug 25th, 13, 06:30 PM Thread Starter
James
Anyone?
post #9 of 13 (permalink) Old Aug 25th, 13, 10:31 PM
Monty
I am looking at the same size wheels but will have a Baer setup. They are 1/4" thick versus stock drums at a little over an 1/8" from what my research says. In view of this I will be going with a 4.875 here I was thinking 4.75 as it was in the middle of the range you stated. Is it possible to do a test fit???
fishface is offline
post #10 of 13 (permalink) Old Aug 26th, 13, 04:22 AM Thread Starter
James
I wish I could do a test fit. Once I order the wheels, custom, they are mine. No returns. That's why I'm so concerned about it. I don't want to waste $700... You know?
post #11 of 13 (permalink) Old Aug 26th, 13, 04:46 AM
Monty
I can understand that. If it is an option go with more backspace. You can always use a spacer plate.
fishface is offline
post #12 of 13 (permalink) Old Aug 26th, 13, 06:00 AM Thread Starter
James
That's very true. I think I might just go with the 4.75" because that is what 75% of people on here are running. That way, if it doesn't fit, then I can jut resell them for a small loss.
Thanks!
post #13 of 13 (permalink) Old Aug 26th, 13, 02:05 PM
Ed
I have a 67 that I used 18x 8.5 with 4.5 back space. they rubbed or bottomed out now and then at the top if I hit a good size bump.
I put disc brakes on the car , and had to change to 4.75 back space because i could not turn the wheel very far without rubing.
the tires will now just touch the frame on the inside if I turn very sharp.
but are a lot better that before.
edwmck is offline
