1968 Camaro - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 9th, 13, 11:14 AM Thread Starter
Rick
1968 Camaro
I have a stock 1968 Camaro and need a stock 15" rim for a spare tire. What Year 15" rims will fit my car?
Rick
Vintagesound is offline
post #2 of 3 (permalink) Old Oct 10th, 13, 02:16 AM
Kevin
SixtyAte's Avatar
Re: 1968 Camaro
Hi Rick,
Any GM rim with 4-3/4" bolt pattern will fit provided its a stock wheel. Unsure if you want a steel wheel or a rallye wheel. A standard rallye wheel has a 4.25 backspace which is what I run on my 68. Any aftermarket wheel/rim may not be the same backspace as the others you have. It should be noted that 15" wheels were only available from the factory on a 1968 Z28 however could be ordered from the dealer.
Kev
SixtyAte is offline
post #3 of 3 (permalink) Old Oct 10th, 13, 01:33 PM
Anne
Re: 1968 Camaro
If you're wheels are 8" wide , you'll want 4.5" backspace :
http://www.summitracing.com/search/b...rder=Ascending
Lawrence454 is offline
