best front tire size for 69 17x8 inch wheel ?? - Team Camaro Tech
post #1 of 9 (permalink) Old Oct 20th, 13, 03:52 PM Thread Starter
cj
im trying to figure out what the best front tire size for my 69 camaro i will be running a 17x8 inch wheel with 5 inch backspace i know the backspace is a bit of an issue im planning on running a 1/2 inch spacers thanks
fltblk69 is offline
post #2 of 9 (permalink) Old Oct 20th, 13, 05:02 PM
DjD
DjD's Avatar
Re: best front tire size for 69 17x8 inch wheel ??
Ideal on the front is 17x8 with 4.75" bs so you want a 1/4" spacer not 1/2". Then you could probably run a 245/45/17 tire with the right alignment and button head fender bolts in the upper most fender bolt position.
...Dennis
DjD is offline
post #3 of 9 (permalink) Old Oct 20th, 13, 05:26 PM Thread Starter
cj
ok thanks very much do you know if i'll be ok with 5 inch backspace in the rear or will i have to space rears out as well
fltblk69 is offline
post #4 of 9 (permalink) Old Oct 20th, 13, 07:14 PM
DjD
DjD's Avatar
Same wheel size 17x8? If so 5" bs will work but that is a bit more bs than and 8" wheel needs.
...Dennis
DjD is offline
post #5 of 9 (permalink) Old Oct 21st, 13, 02:36 AM Thread Starter
cj
yes same size wheel i have disc brakes out back to if that makes a difference
fltblk69 is offline
post #6 of 9 (permalink) Old Oct 21st, 13, 06:56 PM
Chris
I just put new Nitto NT555's on 17x8 Vintage Wheel Works with a 4.75 BS. Tire size is 235-45-17, no rubbing problems identified yet, but I haven't put on too many miles yet.
ctcz28 is offline
post #7 of 9 (permalink) Old Oct 22nd, 13, 01:53 PM Thread Starter
cj
hey Dennis does it matter if i disc brakes out back thanks
fltblk69 is offline
post #8 of 9 (permalink) Old Oct 22nd, 13, 02:03 PM
Steiner
If you're going to run same size rim front and back, I would run same backspace front and back which would mean 1/4" spacers all around for you...unless you're into front wheel drive Pontiac wide track that runs the front track wider than the back.
This is 235/45 on 17x8 with 4.75".
This is wheels all same backspace and same tire size on four wheel discs. Only 4" backspace and 7" rim but gives you an idea of how the tires line up. Imagine the rear ones tucked in another 1/4" if you didn't do spacers in the back.
'69 Camaro
500hp/538lbft
Steiner is offline
post #9 of 9 (permalink) Old Oct 22nd, 13, 02:47 PM Thread Starter
cj
ya i hear what your saying i was just a little uneasy about running spacers out back i got a good deal on a set of centerlines so im trying to make them work they have 255 on all four corners so im swapping the fronts so they'll fit
fltblk69 is offline
