1969 Camaro Bremmer Craft wheels question - Team Camaro Tech
post #1 of 11 (permalink) Old Jan 2nd, 14, 09:18 PM Thread Starter
Hi I am interested in buying http://www.tirerack.com/wheels/Wheel...All&sort=Brand for my 1969 Camaro but I'm not sure if they will fit. I want to get 17's. Thanks!
69camarofan1 is offline
post #2 of 11 (permalink) Old Jan 2nd, 14, 09:30 PM
Thumbs up Re: 1969 Camaro Bremmer Craft wheels question
Those look great. Can't help on fit. But really want to see them on your car and what size you go with
1969
JCSS396 is offline
post #3 of 11 (permalink) Old Jan 3rd, 14, 08:29 AM Thread Starter
The size of the wheels are 17.8. The problem is that these wheels have a offset of 45 mm backspacing of 6.26 and a bolt pattern of 5-112. A 69 camaro has different offset backspacing and bolt pattern but is there a way to get these to fit?
post #4 of 11 (permalink) Old Jan 3rd, 14, 08:36 AM
DjD
DjD's Avatar
Not a practical way to use what you describe. You want a +6 offset front and back with what ever size wheel you select. You'll spend a few hundred dollars on wheel adapters to correct the offset and match the bolt pattern. Shop around, you'll find wheels that look almost like those in the correct spec's...
...Dennis
DjD is offline
post #5 of 11 (permalink) Old Jan 3rd, 14, 10:09 AM Thread Starter
So I need to find wheel spacers for a 5 by 112 wheel that adapts to a 5 by 475 bolt pattern?
post #6 of 11 (permalink) Old Jan 4th, 14, 08:27 AM Thread Starter
Would these spacers work?
http://www.ebay.com/itm/161040797920...%3AMEBIDX%3AIT
post #7 of 11 (permalink) Old Jan 4th, 14, 09:30 AM
DjD
DjD's Avatar
You might be able to bolt a 5x112 wheel onto a 5x114 hub but it's going to damage the wheel when you torque the lugs. As far as the space width, that 1.25" spacer is going to reduce the wheels back spacing from 6.26" to 5.01" and you really want a 4.75" back spaced 8" wheel up front where it will be the most critical.
You seem really set on these wheels, is the close out deal that good that even after buying spacers it's still a killer deal? Looking online it seems early on tire rack couldn't deliver (never in stock) and now they are closing out all but a couple models! On top of that the manufacture doesn't seem to have a web site, what do you know about the brand?
There are so many brands out there and you don't seem to be trying to push the size limits so there should be plenty of other wheels in stock that would fit a '69 Camaro without spacers.
...Dennis
DjD is offline
post #8 of 11 (permalink) Old Jan 7th, 14, 11:25 AM Thread Starter
Bremmer Kraft wheels are like the wheels lots of people use on audi's. I can't find any similar rims with my bolt pattern other than the outrageously expensive forgeline wheels. If anyone can find similar wheels let me know...
post #9 of 11 (permalink) Old Jan 7th, 14, 06:23 PM
George
Gbauer's Avatar
I've been looking for quite some time. Nothing so far...
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #10 of 11 (permalink) Old Jan 11th, 14, 02:23 PM Thread Starter
I believe these are the closest wheels i can find they're the stock zr1 rims. They have the same bolt pattern but nothing else. Let me know what you think and any advice on getting them to fit perfectly. http://www.amazon.com/Strada-Replicas-Gunmetal-Partnumber-121H-886156/dp/B00DUOCYCA
post #11 of 11 (permalink) Old Jan 11th, 14, 02:49 PM Thread Starter
http://www.ebay.com/itm/18x8-5-Gunme...7acaef&vxp=mtr
