New Wheels, New Issues...? - Page 3 - Team Camaro Tech
post #31 of 38 (permalink) Old May 30th, 14, 08:49 PM Thread Starter
James
Re: New Wheels, New Issues...?
Thank you all for your help and infinite wisdom.
I ended up doing tons of measurements of the wheels, frame rails, axle tubes, perches, wheel well, etc. I came to the conclusion that my rear was almost perfectly centered (about 1/8" to the passenger side).
I decided to trim the fender lip, but making sure to not trim to the spot/pinch welds. I ended up getting around 1/4" of space on both sides. I think I'll be able to keep my 275/40/18s after all. Here are some pics:
CamaroMan469 is offline
post #32 of 38 (permalink) Old May 31st, 14, 07:17 PM
Glad you made them work. They sure look good.
Mike68RS is offline
post #33 of 38 (permalink) Old May 31st, 14, 07:32 PM Thread Starter
James
Thanks Mike!
post #34 of 38 (permalink) Old Jun 1st, 14, 06:40 AM
Chad
Wow that is a great looking car! Glad you got them to work.
1969 Camaro SS X66
496 BBC
69bigblok is offline
post #35 of 38 (permalink) Old Jun 1st, 14, 07:49 AM
Brent
67Rally's Avatar
Yeah, that looks great. Nice work. Maybe post pics if the fender trimming for future reference?
67Rally is offline
post #36 of 38 (permalink) Old Jun 1st, 14, 09:32 AM
Andrew
Andrew69's Avatar
Looks great! Perfect fit.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #37 of 38 (permalink) Old Jun 1st, 14, 12:49 PM Thread Starter
James
Thanks for the compliment!
Unfortunately, I didn't take any pictures during the trimming process , but I do have a finished product picture. I'll post that below.
This was my process:
1. Remove trim
2. Measure from pinch/spot weld to inside of fender lip
3. Make marks at a reasonable distance away from the weld
4. Make a "comfort guide line" with a scribe along that line
5. Use painters tape to help protect the finished exterior paint
6. Use electric sheet metal shears to trim along that line (make sure to angle the shears so the handle is away from the outside finished paint)
7. Test fit the rims and use a straight edge to check clearances from about "10 to 2"
8. Once you are happy with the amount of trimming, reattach the fender trim
9. Use a fine tip marker to go along the top edge of the newly cut fender lip, marking the cut line for the trim piece
10. Take the trim back off and cut the trim piece to fit the fender
11. Reinstall the trim piece and make sure it follows your cut line (I had to drill new holes closer to the outer fender for 3 of the trim screws)
12. Next, I used a die grinder with a soft stone to soften the edges and remove the sharp pieces (I made sure to go very slowly and take breaks so that the metal didn't heat up too much and wreck the paint)
13. Have a beer (or two...or five)
14. Go back and prime and paint the bare metal that you just created. You'll thank yourself later.
The entire process took me about an hour per side (not including the priming/painting). It wasn't bad at all. Keep in mind that I'm a novice at this kind of stuff. I had never used sheet metal shears in my life, but man was it easy.
Here is a picture of the passenger side finished product:
It may not be perfect, but I am overall happy with the result. Keep in mind that I only trimmed the area at the top that the tire has a chance to touch. You'd only notice it if you crawled under the car and looked for it.
post #38 of 38 (permalink) Old Jun 1st, 14, 12:52 PM Thread Starter
James
Thanks!
I also wanted to add: I took a 2 hour round trip yesterday on Michigan roads (terrible potholes, etc) with speeds ranging from a creep to 80 MPH and I have no rubbing or scratches of any kind on the tires. I think my Hellwig rear sway bar may be helping a bit, but it's good news nonetheless.
