What do you use on the white letters to clean them - Team Camaro Tech
post #1 of 18 (permalink) Old Jul 21st, 14, 03:51 PM Thread Starter
I have tried many things on my raised white letters. They just do not pop like they should!
What the he.. Will get these things white?
Type of cleaner?
Type of brush?
Ect...
67 383 stroker 460hp RS SS clone 4sp blk on blk m21 Chevelle 12 bolt rear end
Hys67Camaro is offline
post #2 of 18 (permalink) Old Jul 21st, 14, 04:54 PM
Rich
Re: What do you use on the white letters to clean them
I use Westleys Bleach White and a scrub brush. Gets letters bright white and tires a beautiful clean flat black.
69zee is offline
post #3 of 18 (permalink) Old Jul 21st, 14, 04:55 PM Thread Starter
Rich,
Thanks is that a liquid
post #4 of 18 (permalink) Old Jul 21st, 14, 04:57 PM
Garth
Westley's Bleche Wite. Short stiff brush.
Black Magic bought it, not sure if it's still the same product.
I use Simple Green diluted for a lot of stuff too.
1969 Camaro SS 350 LeMans Blue
2015 Z/28 - Red
2 x 1967 R/Tís
1977 Power Wagon
1978 Liíl Red Express
69L48Z27 is online now
post #5 of 18 (permalink) Old Jul 21st, 14, 07:59 PM
Chris
130fe's Avatar
Put them on the inside... ;-). Yeah, the westleys stuff works really well with a stiff brush. http://www.lifeandhome.com/westley-s...FZRgfgod9UYA7Q
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #6 of 18 (permalink) Old Jul 21st, 14, 09:18 PM
69z28freak's Avatar
SOS pads. Works great.
Grandma, 69.5, Z/28 Finally Done! Well almost...
My Build Thread
69z28freak is offline
post #7 of 18 (permalink) Old Jul 21st, 14, 10:27 PM
Steps
Bleach and /or water blaster
Steptoe is offline
post #8 of 18 (permalink) Old Jul 22nd, 14, 01:32 AM
Tim
Not familiar with some of those products, but if you do use bleach (or products that contain bleach), make sure it's diluted and you rinse it off well afterwards. Bleach can dry certain rubber compounds, causing cracks.
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Sold Clippinger Chevrolet. Raced at Lions in LA.
ZLP955 is offline
post #9 of 18 (permalink) Old Jul 22nd, 14, 04:26 AM
Jonathon
Smitty68's Avatar
Clorox clean-up, you can sneak it out of the house without the boss knowing..
Seriously it works great! Spray it on and let it sit a few minutes then scrub it with a brush and rinse.
http://www.clorox.com/products/cloro...leaner-bleach/
68 Resto-Mod in progress..355sbc .350 Trans Rushforth wheels
My Build:
Smitty68 is offline
post #10 of 18 (permalink) Old Jul 22nd, 14, 04:51 AM
I don't have raised white letters on car tires, but I do on two Harley's, one of which has raised wide white walls and that is a lot of white surface area to clean.
The Westley's stuff works pretty good, but what I've found is depending on the age of the white rubber is that sometimes to get the white to really pop it's more like removing the top layer of rubber than just cleaning it. This is when and why a stainless steel wire brush and/or SOS pads do so well. Kind of the same process as wet sanding and polishing really old paint, except with rubber the tools used are different. I've even used wet sand paper before to "uncover" the white rubber below the surface and that has worked well.
On a motorcycle with white walls, I jack the bike up and can spin the wheel while holding the brush, SOS pad or wet sand paper against the rubber on the tire to be cleaned. This works pretty good, very good if you carefull run the bike in gear at an idle as the rear wheel is turning on it's own for you. The front wheel requires the "Armstrong" method be used. On a car tires, jacking the wheel off the ground can help but just turn the wheel by hand to orient it to the best cleaning position. The cleaners help, but it's "elbow grease" that really produces results in my experience. As always, your mileage may vary...
NH69Z28RS is offline
post #11 of 18 (permalink) Old Jul 22nd, 14, 05:02 AM Thread Starter
Thanks to all that have replied!
Chris you might have the best idea! Put the letters in and give up!
I will try some of these ideas.
Most products say do not get the stuff on the aluminum wheels. That makes it harder to do!
Next time I buy tires I think I will pass on the raised white letters but these tires only have 300 miles on them.
The smaller tires in the front look good. It is the larger rear tires with larger white letters that just look a little off white and it drives me crazy!!!
post #12 of 18 (permalink) Old Jul 22nd, 14, 06:46 AM
Tim
Originally Posted by Hys67Camaro View Post
......white letters that just look a little off white and it drives me crazy!!!
I've heard of guys who show their cars a lot using white paint on a small brush to keep the RWL looking fresh and bright..... Might seem a little obsessive, but maybe it's not such a bad idea?
ZLP955 is offline
post #13 of 18 (permalink) Old Jul 22nd, 14, 08:01 AM
DjD
DjD's Avatar
Type of cleaner?
Type of brush?
Ect...
I've never seen anything work better than an SOS pad on white walls or white letters.
...Dennis
DjD is offline
post #14 of 18 (permalink) Old Jul 22nd, 14, 10:50 AM
Vega$69's Avatar
I've always used Comet Cleanser
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #15 of 18 (permalink) Old Jul 22nd, 14, 11:00 AM
George
Gbauer's Avatar
I went a step further and just got new tires. ...and 17" wheels.
I used to use Wesleys and/or a SOS pad. Either one works fine.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
