A true 4.88 gear - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 23rd, 14, 07:02 AM Thread Starter
TED
A true 4.88 gear
I have a 69 camaro and was trying to figure gear ratio to race car. 358 small block, turbo 350 trans 5500 stall conv. 14/32/15 slicks. what is the true gear ratio of a 4.88 gear with 32 in slick 456, 411 or what ?
TED SMITH is offline
post #2 of 5 (permalink) Old Jul 23rd, 14, 06:00 PM
Re: A true 4.88 gear
What I think you are asking is a street tire is roughly 26 inches tall so by going to 32 inch slick in effect reduces your final gear ratio. My calculations suggest it would be like running a 3:58 gear with a 26 inch tire. The experts I am sure will responsed as well and more than likely have better insights into the true ratio then myself.
meusebi is offline
post #3 of 5 (permalink) Old Jul 23rd, 14, 06:12 PM
Sorry I did the calculations wrong it would be like running a 3:97 gear.
meusebi is offline
post #4 of 5 (permalink) Old Jul 23rd, 14, 08:35 PM
4.88 is 4.88 no matter what size tire you use. The tire will turn once for each 4.88 turns of the input shaft. You can use one of the many online calculators to see what difference changing tire sizes and gear ratios will make.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #5 of 5 (permalink) Old Aug 8th, 14, 10:47 AM
Eric
Easy calculation to make comparisons:
(MPH) X rear gear ratio X 336 / tire height
Example:
60 X 4.56 X 336 / 28 = 3283 rpm
60 X 4.88 X 336 / 28 = 3513 rpm
In your case:
60 X 4.88 X 336 / 32 = 3074 rpm
As a comparison:
60 X 4.10 X 336 / 28 = 2952 rpm
Your 4.88 with a 32" tire is the rough equivalent of a 4.10 gear with a 28" tire.
Hope that helps.
Carburetor Rebuild & Restoration
Engine & Driveline Parts & Services
Vintage Musclecar is offline
