Tire Pressure 17" Nitto 555 - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 29th, 14, 04:42 AM Thread Starter
Steven
Running Nitto 555 tires on 17" centerline wheels, 285/40/17 235/45/17 What pressure do you guys recommend? (69 Camaro big block car)
ssenay72 is offline
post #2 of 5 (permalink) Old Jul 29th, 14, 05:25 AM
Re: Tire Pressure 17" Nitto 555
I have 18" Nitto 555's, 255 on back 235 front and I keep them at 35 pounds all the way around. Nice middle number. I think the max pressure is 50?
brian2013 is offline
post #3 of 5 (permalink) Old Jul 29th, 14, 06:50 AM
DjD
DjD's Avatar
My Nitto 555 tires are max cold rated at 44psi. I run them somewhere between 32 and 36psi depending on driving conditions, a little less for better traction and a little more for better fuel economy on the long drives.
The only time you would ever go near the tires max psi rating is if you were hauling bricks in the trunk and 4 - 400lb passengers in the car!
I guess I should include I have 235/45 17 and 255/45 17 tires.
...Dennis
DjD is offline
post #4 of 5 (permalink) Old Jul 29th, 14, 01:23 PM
Brent
67Rally's Avatar
FWIW, I have Nitto 555's as well, 275/40/18 and 245/40/18. I contacted Nitto about tire pressure recommendations for the street as well as for Autocross. They recommended 32psi front and 29psi rear for the street.
67Rally is offline
post #5 of 5 (permalink) Old Jul 29th, 14, 01:38 PM
Steiner
I run 32 after dropping down from 35. Getting even wear out to the edges now. 2002 camaro with 245's spec at 30 so figure ours should be in the area.
'69 Camaro
500hp/538lbft
Steiner is offline
