225 70 R14 Replacement-some rubbing up front - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 3rd, 14, 12:44 PM Thread Starter
Matt
I've got the 14" rallys and my tire is a gy eagle st 225 70 r14. I'd like to stay close to stock looking. My current tires will rub up front if I crank the wheel all the way. What size do you recommend replacing them with? I like the raised white look. My suspension appears to be stock. Thanks!
'68 327 Coupe SS Clone(I think)
mkoon is offline
post #2 of 4 (permalink) Old Aug 4th, 14, 03:03 AM
George
Re: 225 70 R14 Replacement-some rubbing up front
What's the backspacing on them?
482 New ZL1 Block
HR 250 @ 50 107 Lobe SEP
Pro Systems 4150
AFR 315s 11.3:1 Ported 163 Manifold
Auto gear M22W 410 12 Bolt
482 ZL1 is offline
post #3 of 4 (permalink) Old Aug 4th, 14, 07:35 AM
DjD
DjD's Avatar
The 225/70-14 is 26.5" tall with a 9"section width, a 215/70-14 is 25.9" tall and has an 8.7" section width. Both have a 6.7" tread width.... If you are just looking for a slight size change the 215/70 might do the trick.
...Dennis
DjD is offline
post #4 of 4 (permalink) Old Aug 5th, 14, 04:15 AM
I had 225/70-14 on the 67 stock steel rims and had the same problem. I switched to 215/70-14 and the problem was solved.
Torch is offline
