wheel offset - Team Camaro Tech
post #1 of 2 (permalink) Old Aug 10th, 14, 09:23 AM Thread Starter
p.j.
wheel offset
building a 69 put a rear end out of a 80 trans am w/ disc brakes , can anyone suggest what wheel offset I will need to use. thank you
p.j
overhaul2 is offline
post #2 of 2 (permalink) Old Aug 10th, 14, 12:28 PM
DjD
DjD's Avatar
Re: wheel offset
Not a common swap, it's probably going to be on you to figure out something to measure from the wheel mounting surface to the inner edge of the wheel well so you know what clearance you have. You also need to determine what size wheel will clear the lower shock mount and if the shock itself will be in the way and rub. Don't forget caliper clearance inside the wheel too!
...Dennis
DjD is offline
