rally wheel tire combo question - Team Camaro Tech
post #1 of 9 (permalink) Old Sep 3rd, 14, 06:16 PM Thread Starter
morgan
X77Z28MP's Avatar
Hi I have a 69z with YH rallys im looking at yokohama tires 225/50R 15 will these fit on the rear. stock ride height, Looking to buy these any comments or ideas would be helpful thanks
69Z X77 Lemans Blue 03D work in progress
X77Z28MP is offline
post #2 of 9 (permalink) Old Sep 3rd, 14, 06:34 PM
Kevin
Re: rally wheel tire combo question
Morgan,
Unless you've done something to the rear wheelhouse (ie. minitub), my guess is you would experience rubbing on the inner side. I don't recall the BS on the YH wheels (4.25- 4.5?) but still seems it could be an issue.
Kevin
KevinK7 is offline
post #3 of 9 (permalink) Old Sep 4th, 14, 03:33 AM
Steiner
225/50? Those are going to be kinda short and might not look right, less than 24" tall. I think a 255 might be about as big as you wanna go on a 7" wheel. Some run up to a 275 on a stock wheel but it'll stick out on stock backspacing and kinda "bulge" on the wheel. Have to run 5.5" or so to get it to tuck under the fender lip.
Here's 235/60R15 at 26" tall on an FW wheel which should have identical measurements as the YH, 4.25" backspace. No issues with these. BTW this pic is about to turn 21 years old.
Same size 235/60R15 tire but on a Year One 15x7 Rally built with the wrong backspace, only 4". They hit the front fender nuts on hard turns under compression.
'69 Camaro
500hp/538lbft
Steiner is offline
post #4 of 9 (permalink) Old Sep 4th, 14, 04:31 PM Thread Starter
morgan
X77Z28MP's Avatar
Thanks Kevin/Steiner for your fast responses. That's a sweet ride I like the way the tires fit I'm going with the 235/60 Thanks again Morgan
X77Z28MP is offline
post #5 of 9 (permalink) Old Sep 4th, 14, 04:41 PM
69z28freak's Avatar
Hey guys not to hi-jack this thread but I have the same 235 tire combination on my 15x7 FW Rally wheels. Is the back spacing the same on the FW as the YH. Also not to sound stupid. But what is backspacing? Duh!
Grandma, 69.5, Z/28 Finally Done! Well almost...
My Build Thread
69z28freak is offline
post #6 of 9 (permalink) Old Sep 4th, 14, 05:51 PM
Steiner
Yeah Mike, pretty sure they're identical.
Backspace is from the back of the wheel mounting face to the very back edge of the wheel.
'69 Camaro
500hp/538lbft
Steiner is offline
post #7 of 9 (permalink) Old Sep 5th, 14, 05:59 PM Thread Starter
morgan
X77Z28MP's Avatar
If I wanted a wider tire what size should I look for 235 50 15 just curious
X77Z28MP is offline
post #8 of 9 (permalink) Old Sep 5th, 14, 06:24 PM
Steiner
First number is the width in mm.
Second number is sidewall height percentage of width.
235/60 is 235mm wide with a sidewall = 235 x 0.60
So, a 235/50 would be the same width but shorter.
The idea is to use the math to figure out how to get your width where you want it and the overall height where you want it.
235/50R15 height = ((235 x 0.50 x 2) 25.4 ) + 15
Convert tire sidewall top and bottom to inches and add rim diameter.
'69 Camaro
500hp/538lbft
Steiner is offline
post #9 of 9 (permalink) Old Sep 6th, 14, 08:18 AM Thread Starter
morgan
X77Z28MP's Avatar
Thanks for the info I get it now
X77Z28MP is offline
