So how big can you go? - Team Camaro Tech
post #1 of 14 (permalink) Old Apr 19th, 00, 02:50 PM Thread Starter
I thought this picture would be of interest. It is a set of 31.5 by 11.5 slicks on 15 inch Supertrick rims. The offset is 4.5-4.75 and the actual tire contact patch is 14 inches of rubber per side! http://photos.yahoo.com/bc/supertrick1
Look under the Finished Camaro Album. The other album has before pictures. This whole car project was started in November of last year.
[This message has been edited by pink68 (edited 04-19-2000).]
pink68 is offline
post #2 of 14 (permalink) Old Apr 21st, 00, 07:55 AM
Nice looking Camaro.... I have a set of M\T slicks that I bought from a friend like new... when I mount them, I have very little clearence between the slick and the outer edge of the body... looks like you don't have much clearance either... just wondering how much these tires (grow) during a burnout. I think my tires are 31/ 10.5
mburke is offline
post #3 of 14 (permalink) Old Apr 26th, 00, 04:24 PM
Pink68, what size rims are you running with the 275/60's in the rear and how much do they stick out of the wheel well? Do you have any rear shots with the 275's?
gearhead67 is offline
post #4 of 14 (permalink) Old Apr 27th, 00, 06:25 AM Thread Starter
mburke - the slicks are bias ply and grow about and inch or so. there is actually almost a little more than two inches between the fender lip and the tire surface. The rims are Supertricks 15 by 10 with a 4.75 offset. The interior fit is very tight especially on the drivers side and requires some judicious "realignment" of the inner fender lip/body pan junction. I didnt want to fully tub the car and relocate the springs so chose this method. If I had a 4 inch offset inner piece for the supertrick then it would have been a perfect fit but thats the price we pay for modification, right?
gearhead - the 275 T/A radial street tires are on Autodrag (05) that are sized 15 by 8 1/2 with the 3 5/16 offset. They also DO NOT stick out of the fender well. There are two offsets available with the other being 4 1/2 or so. I would rather have the other offset but I got the entire wheel set (front and back) for free including the front tires. I am too cheap to buy new ones yet.
web page at <A HREF="http://hometown.aol.com/winterjl/index.html
and" TARGET=_blank>http://hometown.aol.com/winterjl/index.html
and</A> more pictures at http://photos.yahoo.com/supertrick1
pink68 is offline
post #5 of 14 (permalink) Old Apr 28th, 00, 09:57 PM
When you say that they do not stick out then they must be dead even with the lip. Just to make sure I understand you 100%, you can stand right up to your car and look down at the fender and not see any tire. Do you have your inner fender lip rolled?
post #6 of 14 (permalink) Old Apr 29th, 00, 07:14 AM Thread Starter
gearhead - yes, you are right. I am going to take a series of photos later today (I am going to a car show right now) and post them at http://photos.yahoo.com/supertrick1 - they wont be up probably till 4pm pacific or so. I will take a number of photos from under the car, behind, above etc. once you have seen them just let me know and I will delete them from the album.
pink68 is offline
post #7 of 14 (permalink) Old Apr 29th, 00, 08:10 PM
Lonnie
gearhead67, the 67 i just bought had 275 60 15's on centerline convo pro's 15X8.5 with 3 and 5/16 backspacing. The sidewalls stick out of the body and rub like crazy. I sold the wheels and bought 15X8.5 convo's with 5" backspacing. The backspacing actually measures 4 3/4. I rolled the lip. The driver side is kinda close to the inside and rubs a little on a hard right hand corner. The passenger side never rubs. I think a 1/4 inch spacer on the driver side will cure the problem. Maybe poly bushings and a sway bar will help also.
67 410sb 11.63 @117.6
Lonnie67 is offline
post #8 of 14 (permalink) Old Apr 30th, 00, 02:01 PM Thread Starter
gearhead - the pictures are posted at http://photos.yahoo.com/supertrick1 if you could please email me or post when you have looked at them so that I can delete the picture album - Thanks!!!
pink68 is offline
post #9 of 14 (permalink) Old Apr 30th, 00, 05:26 PM
Lonnie
gearhead, my car sits stock height. I have single leafs and regular shocks. I do have slapper bars and the snubbers do touch the springs and make the suspension stiffer and reduces body roll. Pinks tire pics look about the same as mine did, hard to tell because my car sits lower. Also be careful about the rims you buy, brand to brand is inconsistant with their width ratings. Centerline is right on, weld is 1/2 inch narrower than advertised. The backspace on my other camaro with autodrags is exact at 4 7/8 but the convo's rated at 5" measure at 4 3/4. The billet centerlines on my wife's car are exact. Just something to look out for. If you want it to sit fairly low, rolling the lip is a must. My suggestion is an 8" with 4.5 bs. This is also what Car Craft recommended for 1st gens in a recent article. But they said 255's. What brand of wheels are you looking to get?
Lonnie67 is offline
post #10 of 14 (permalink) Old May 2nd, 00, 07:25 PM
Pink68, Thanks a bunch for the photos. Nice paint job, smooth as glass ... I can even see the kiddie play slide in the reflection. This has helped me out alot, thanks.
Lonnie67, I currently have 15x8 ralley rims off of a corvette. I would like to get a set of Draglites but I need other things before them. My buddies want me to go with the Pro Touring look but 17" rims really hurt the wallet!!
post #11 of 14 (permalink) Old Jul 11th, 01, 01:20 AM
Talking
what's the backspace on your front centereline wheels? 3 5/16? and what tire size you use with that bs? 4 7/8 on rear?
Hotrod76 is offline
post #12 of 14 (permalink) Old Jul 16th, 01, 11:25 PM
<BLOCKQUOTE>quote:</font><HR>Originally posted by Hotrod76:
what's the backspace on your front centereline wheels? 3 5/16? and what tire size you use with that bs? 4 7/8 on rear?<HR></BLOCKQUOTE>
HotRod
I have Centerlines on my 69. Fronts are 15x7 w/3.3125 backspacing, Tires are 235/60 (9.65" wide measured on rim). Also had 225/60 on before (9.5" wide measured on rim). Some rubbing between outer shoulder of tire and wheelwell during tight turns. Probably could be eliminated by slight reshaping of wheelwell for clearance.
On backs have 15x8.5 w/ 4.875 bckspacing. Tires are 255/60 but are fatter than most (actually measure at touch over 11" on rim. BFG 265/50 15s are rated to measure 10.9 on same width rim) Some rubbing on inside when one side of rear end moves up, like driving up a ramp on an angle. Some big hammer shots might cure that.
my69gofast is offline
post #13 of 14 (permalink) Old Jul 17th, 01, 10:45 AM
2 days ago I saw a 67 with 275's in the back, they were street slicks, and the guy who owned the car said that the fit just fine. Also, the car was lowered in the back, and I think the lip was really rolled in order to have the tire fit inside the wheel well. He said that he hadn't done any tubbing though.
lil_beast_67 is offline
post #14 of 14 (permalink) Old Jul 18th, 01, 04:58 PM
Thumbs down
Nice Camaro to bad its purple.
capone is offline
