Anyone running Comp T/A drag radials? - Team Camaro Tech
post #1 of 14 (permalink) Old Jul 30th, 00, 06:04 AM Thread Starter
Drake
Cool
I was looking into putting these on my 67'.Anyone running these?Notice-DRAG radials,I have run regular T/A's before.I was going to buy 235/60/15's,as these should fit on my 67' without clearance problems.Good traction?Excellent?Trying to get traction with my redlines is getting old!
67 RS RAGTOP # matching
4X4 Chevy truck
4X4 Suburban
67drake is offline
post #2 of 14 (permalink) Old Jul 30th, 00, 07:12 AM
Jody
camcojb's Avatar
I ran the 235/60-15 drag radials on a 67 Nova. They are better than any street tire I've seen but no comparison to an E.T Street or slicks. They are however very driveable. I currently run the 325/50-15 on a Chevy powered Cobra replica and the 275/50-15's on a 72 Camaro. My opinion is they are much better than a standard street tire. For maximum e.t. though I would run the E.T. streets.
Jody
camcojb is offline
post #3 of 14 (permalink) Old Jul 30th, 00, 09:32 AM Thread Starter
Drake
Thumbs up
Thanks Jody.
Actually I WAS looking at the E.T. streets and Hoosiers,but I read in the catalogs that the width of the tire on these is 10.5" or larger.I did a search on 67' rear wheel clearances and it seems like 10" is max width without mods or the jacked up 60's look.I have a very stock looking car.If I can run one of these 10.5's I would have alot larger seletion to choose from.
4X4 Chevy truck
4X4 Suburban
67drake is offline
post #4 of 14 (permalink) Old Aug 7th, 00, 07:11 AM
I ran the 235/60/15 's for a while. IMHO they work fine on the track, but are lacking on the street. Still better than a normal radial tire, but not as good as the Hoosier QTP or M/T tires.
Mark W. Winning is offline
post #5 of 14 (permalink) Old Aug 8th, 00, 08:43 AM
I have a set of 235/60/15 drag radials I sometimes use on my 67. They hook very well on my car but it's not that fast, 13.10 @ 108mph. NMCA Factory streeters are running 9's on 275/60/15 drag radials, so you can make them hook good if you work at it. The et streets and hoosiers will hook better but the difference in handling is pretty big. They are made for straight line acceleration only. They are bias ply tires which will make them wander around quite a bit.
I guess it really depends on how you want to drive the car and how much power you are trying to put to the ground.
Stephen
67 RS/SS 350 700R4
69 SS clone unfinished
72 454 Weekend Racer
squarles is offline
post #6 of 14 (permalink) Old Aug 8th, 00, 07:00 PM Thread Starter
Drake
Wink
Thanks for the replies.I'm only running [email protected],with no traction.So I am far from overpowered!I hope to get around 13.8 or so with the new tires.
4X4 Chevy truck
4X4 Suburban
67drake is offline
post #7 of 14 (permalink) Old Aug 9th, 00, 04:42 AM
I would use the drag radials. They work best on my car at 15psi. I have very little wheel spin on the street and none on the track. The only traction aid I have is competition engineering slapper bars on the stock mono leaf springs.
Have fun,
Stephen
67 RS/SS 350 700R4
squarles is offline
post #8 of 14 (permalink) Old Aug 11th, 00, 03:20 PM
I run Hoosier quick time pro dots on my 69 and there is plenty of room to spare. They are 26x9x15. I drove on the street with 22psi in them and they were fine. I dropped the pressure down to 19 and tried a foot brake launch and the car realy launched! I was running 2.20's 60' at New england dragway on 255/60/15 BFG's. I cant wait to get to the track I know there will be a huge difference! Ill keep you posted. ERIC
vonzipper is offline
post #9 of 14 (permalink) Old Aug 11th, 00, 06:40 PM Thread Starter
Drake
Thumbs up
Thanks for the info guys.I still have not made up my mind for sure what to run,I would like to pick them up before the end of the driving season though.I'm way over "budget" on my car this year!
4X4 Chevy truck
4X4 Suburban
67drake is offline
post #10 of 14 (permalink) Old Aug 12th, 00, 09:17 AM
ok, i too have a problem with wheel spin ( street or track)but how will these bfg's work with 2.73's ?bog on the line then go?
My68Camaro
Doug G.
68 Camaro
406 ci.
post #11 of 14 (permalink) Old Aug 14th, 00, 07:41 AM
Std or auto trans?
67 RS/SS 350 700R4
squarles is offline
post #12 of 14 (permalink) Old Aug 14th, 00, 09:25 AM
me ? auto w/ shiftkit.
My68Camaro
Doug G.
68 Camaro
406 ci.
post #13 of 14 (permalink) Old Aug 14th, 00, 11:26 AM
Doug,
Your car shouldn't bog off the line with an auto, especially if you have your converter stall rpm properly matched to the power range of your cam. With 2.73's it aint gonna blast off the line but it shouldn't bog.
Stephen
67 RS/SS 350 700R4
squarles is offline
post #14 of 14 (permalink) Old Aug 15th, 00, 09:37 AM
pulling 2.06's now at the 60',so i guess i'll wait till the 4.10 rear is installed ( when i have time).
My68Camaro
Doug G.
68 Camaro
406 ci.
