235/60/15 Will they work on front of 68? - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 10th, 00, 05:00 AM Thread Starter
I have spent quite a bit of time researching tire and wheel size for my 68 Camaro. The 235/60/15 seem to look right for all four corners. The problem is, will they rub the front trim/wells? Does anyone have 235's in the front? Do they work. Any other suggestions or sites to look at Camaros w/ tire sizes would be great. Thank for the help!
Sgrouse is offline
post #2 of 6 (permalink) Old Sep 10th, 00, 06:53 AM
That's what I run on the front of my 69', I think the consensus has been that this is the optimum tire size for the front of the first generation Camaros. However, if your suspension is not up to par, they WILL rub. I have new big block coil springs and KYB's on mine, so they have not rubbed at all. You can see pics at my website: http://www.geocities.com/kz1000ltd/
kz1000ltd is offline
post #3 of 6 (permalink) Old Sep 10th, 00, 08:46 AM
JohnZ's Avatar
I have 235/60-15 BFGoodrich Radial T/A's on all four corners of my '69Z and they work fine - no rubs, right look.
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
post #4 of 6 (permalink) Old Sep 10th, 00, 04:28 PM
I've got the same size - Firehawk FTX. Stock springs on the front, small block, '68.
Matt
http://camarotech1.com
Camaro Tech 1st Generation
[This message has been edited by houndog72 (edited 09-10-2000).]
houndog72 is offline
post #5 of 6 (permalink) Old Sep 11th, 00, 08:28 AM
I had 235/60 15 BFG T/A on my 67 at one time. They were mounted on 15 x 7 rally wheels. Mine actually rubbed a little. They only rubbed at full turn. They rubbed the sub frame behind the tire in the direction I was turning. It didn't rub bad enough to bother me. They did not hit any of the trim, it just rubbed a small spot on the frame. They looked good at fit the wheelwell nicely but I eventually went to 16" late model wheels.
Stephen
67 RS/SS 350 700R4
69 SS clone unfinished
72 454 Weekend Racer
[This message has been edited by squarles (edited 09-11-2000).]
squarles is offline
post #6 of 6 (permalink) Old Sep 12th, 00, 05:34 PM
Bret
I had the same problem on my 68 as squarles 67, 15x7 Cragars with BFG 235/60/15-rubbed frame on rear edge at full steering lock-no other problems. I don't remember the backspacing and the wheels and tires are now long gone so I can't help you out with that, sorry.
bretcopsey is offline
