295/50-15 on rear of 69 info - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 2nd, 00, 09:50 AM Thread Starter
Ok guys I am getting real serious about getting some serious meats. I have been measuring and getting exact tire sizes including sidewall width & thread width. I basically have 12" wheelwell to play with but the problem is this- I dont want to run a 275/60-15 because they are 28" tall. The with would work fine but I want to run the same height all the way around and that will rub on the front.
So next I am looking at 295/50-15 which is even wider but here is my question.
If this eagle gt II tire has 12.1" sidewall width (11 tread) on a 9.5" rim, what size would it be on a 8" rim?
or how about cooper 11.77 sidewall (10.1 tread) on a 9.5" rim what would it be on a 8?
What I am trying to shoot for here it to try and get 11.5 sidewall on a 8 so I have 1/4" give on both sides
and Im going to use 245/60-15 on the front
69 Camaro 1977 350
Shift kit, HEI, holley 600, flowmaster delta flow mufflers http://msnhomepages.talkcity.com/rallyrd/murfys_law
[This message has been edited by Murfys_Law (edited 10-02-2000).]
Murfys_Law is offline
post #2 of 4 (permalink) Old Oct 2nd, 00, 01:43 PM
Smile
Murfy's Law,
Fred Puhn's book "how To Make Your Car Handle" says that for every 1/2" change in wheel width, the tire section changes.2". Hope this helps. pdq67
Remember - Measure three times and buy once!!!
post #3 of 4 (permalink) Old Dec 28th, 00, 04:28 PM
Jeremiah
Guest
Posts: n/a
BF does make a 275/50/15 that fits great. Lower profile and a little wider on the tread width. With a 4 1/2" BS
post #4 of 4 (permalink) Old Dec 28th, 00, 06:01 PM
stevo camaro's Avatar
Thumbs up
I've got 235-60-15's on the front with 7" wide wheels. The rears are 295-50-15's with a 10" wide wheel. The tires are goodrich TA's and the height is the same. I'll E-Mail you a pic with the 9" rearend in it vs. the 10-bolt posi in my sorry exscuse for a web page pictures.
I think the front tires your thinking about will rub. Mine are marginal.
67 SS 396,4-sp
67 RS 327,4-sp
72 RS 350/350
69 4X4 suburban 350,4-sp
73 3/4 ton 454/400
http://www.geocities.com/stevocamaro
stevo camaro is offline
