COIL SPRINGS - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 8th, 00, 05:36 PM Thread Starter
Greg
MY 69 IS GOING TO BE A SMALL BLOCK.I'VE BEEN TOLD TO GET BIG BLOCK SPRINGS ANY WAY IS THIS TRUE OR SHOULD I JUST GET SMALL BLOCK SPRINGS.
gregmontgomery is offline
post #2 of 3 (permalink) Old Nov 9th, 00, 03:05 AM
I'm also looking into that. I've got a spare set of big block coils that i wanted to shorten to lower the car 2". I've been told that the higher spring rate (that i'm still looking for) might compensate for the parts i cut off. I was thinking of trying that set up before forking out $$$ for specialty coils. I'll let you know as i go along.
67 camaro
350 SS
BEN-67 is offline
post #3 of 3 (permalink) Old Nov 9th, 00, 04:14 AM
67 camaro
Guest
Posts: n/a
hey all un less you shorten the springs quite a bit the front will look like you just lifted the front wheels off the ground from a dragstrip launch
1967 rs camaro tahoe turquoise
