Sticky street tires? - Team Camaro Tech
post #1 of 8 (permalink) Old Nov 15th, 00, 09:52 AM Thread Starter
Anyone have recommendations for a sticky street tire? I can't get any traction in first gear and would like to purchase tires that allow me to still drive the car, but also get better than average traction.
rlrr is offline
post #2 of 8 (permalink) Old Nov 15th, 00, 11:06 AM
If you have 15" wheel you can go with a drag radial from BFG or other manufactures but the life of the tire is not long. BFG has a autocross tire called the R1 but it is only offered to "racers". I understand that all that is needed to acquire this tire is to be on BFG's racers list which is not hard to do, just sign up basically. Again, this tire will not last long but will handle great. Other than those options above there really is not much else except for your standard BFG Radial T/A and alike, all rated under 112mph.
Joseph
Joseph is offline
post #3 of 8 (permalink) Old Nov 15th, 00, 08:11 PM
Get yourself some Mickey Thompson D.O.T. sticky street tires-they work,I've used them.
80 350/425 is offline
post #4 of 8 (permalink) Old Nov 16th, 00, 10:09 AM
the hot ticket right now ...mt et streets,but be warned, very little traction on wet roads,& short street life.
My68Camaro
Doug G.
68 Camaro
406 ci.
post #5 of 8 (permalink) Old Nov 16th, 00, 10:26 AM Thread Starter
How short is short?
rlrr is offline
post #6 of 8 (permalink) Old Nov 17th, 00, 03:06 AM
I cannot say enough good about the Hoosier Quick Time Pro's. On the street, I they work great. On the track, they work awesome. I normally run a ET Drag slick and pull a 1.60 60ft time. The Hoosiers pulled a 1.55 60ft! They are soft though, but lasted longer than my BF Drag Radials. Probably cause they do not spin.
For a street car, the BF's would be fine and the Nittos are looking real good also.
1992 Firebird 355/Six Speed
1991 RS 350 / 700-R4
1987 Toyota Pickup 383 / 500 + HP 10.963 @ 119.95 Slicks / 11.997 @ 114.23 Radials
http://personal.lig.bellsouth.net/~racer383/
[This message has been edited by Mark W. Winning (edited 11-17-2000).]
Mark W. Winning is offline
post #7 of 8 (permalink) Old Nov 17th, 00, 02:50 PM
depends on burnouts and milage.
My68Camaro
Doug G.
68 Camaro
406 ci.
post #8 of 8 (permalink) Old Nov 17th, 00, 08:55 PM
If you have lots of money and horsepower, M/T E/T Street would be the choice. If lacking cash and less than 400 hp, try McCreary. They've been used by circle track racers for years and work great on the street. Street racers use them a lot. Probably found locally or on the web.
Hals73RS is offline
