Tires/Power Steering - Team Camaro Tech
post #1 of 4 (permalink) Old Nov 15th, 00, 05:53 PM Thread Starter
Will
I currently am driving a non-power steering 68 Camaro. For a while I was driving on some pretty wornout 205/65/R15 front tires and was just killing myself trying to turn the steering wheel when parking or at very low speeds. Well I just replaced those tires with some cheapo off brand tires (same size) and its like I have a different car. I don't have any of the problems I used to have. Now to my question. I was considering upgrading to power steering. Am I just experiencing the thrill of new rubber that will change as the tires wear a little and make me want to get that PS again? Or should I consider this a blessing that will keep me from having to set up that power steering in the future.
wilmarwil is offline
post #2 of 4 (permalink) Old Nov 16th, 00, 10:11 AM
some skinnies on the front will do the same thing.(be easier)
i think your problem was the worn tires,more contact patch.
My68Camaro
Doug G.
68 Camaro
406 ci.
post #3 of 4 (permalink) Old Nov 16th, 00, 10:58 AM
mbrekke's Avatar
Have manual steering on my 68 and it turns easily. I don't really see a need for power steering on a Camaro. A cement truck yes... Camaro no...
Make sure all the front end parts (ball joints, idler arm etc.) are in good shape and greased.
[This message has been edited by mbrekke (edited 11-16-2000).]
mbrekke is offline
post #4 of 4 (permalink) Old Nov 17th, 00, 03:10 AM
If you even turn some higher MPH 1/4 mile passes, you will be glad you DON'T have PS.
Also, if you old tires have worn more on the inside, then the outside, it makes for a hard time turning.
1992 Firebird 355/Six Speed
1991 RS 350 / 700-R4
1987 Toyota Pickup 383 / 500 + HP 10.963 @ 119.95 Slicks / 11.997 @ 114.23 Radials
http://personal.lig.bellsouth.net/~racer383/
Mark W. Winning is offline
