skinnies on the front - Team Camaro Tech
post #1 of 8 (permalink) Old Nov 22nd, 00, 09:41 AM Thread Starter
i sold some parts to a guy a couple years ago that had his ralleys on the front cut and rewelded to fit skinnies. they looked really sick (that means they looked really neat, scottb). i didnt ask him about problems or where he had gotten it done. has anyone had any experience with anything like that? problems? cost?
josh schaad is offline
post #2 of 8 (permalink) Old Nov 22nd, 00, 10:31 AM
stockton wheel, cuts and widens/narrows wheels... they're in Ca.don't know of a site for them.
My '68 Camaro
Doug G.
68 Camaro
406 ci.
post #3 of 8 (permalink) Old Nov 22nd, 00, 12:40 PM
Just a note... I used to work in a garage and by our state laws the front tires had to be at least 60% of the width of the rears. Not to sound like your dad or anything, but that'll give you pretty poor handling for a street car.
Matt
http://camarotech1.com
Camaro Tech 1st Generation
houndog72 is offline
post #4 of 8 (permalink) Old Nov 25th, 00, 03:07 PM
I have had runners on several cars. Some while using drag shock all the way around. It is true the handling is not the greatest, however, you will not incur problems during normal driving. The only time it was necessary to modify my driving was when taking 90 degree turns, even then it was only necessary to slow down slightly.
Steve R.
Steve R is offline
post #5 of 8 (permalink) Old Nov 25th, 00, 04:43 PM
ive seen a guy take the outer rim of a volkswagon and put a chevy rally center in it . not that bad either he used a rear end and a dail ind. to "true it" AND IT WORKED.
toolbox is offline
post #6 of 8 (permalink) Old Nov 26th, 00, 02:47 PM
JWA
Jeff
JWA's Avatar
http://www.stocktonwheel.com/
Jeff
69 SSRS 396(roller 427 )
My Chevs
JWA is offline
post #7 of 8 (permalink) Old Nov 27th, 00, 10:50 AM Thread Starter
thanks for the info
post #8 of 8 (permalink) Old Nov 28th, 00, 09:30 AM
I run "skinnies" on the front and agree with the above. They are not a real problem on the street. They actually turn pretty good. They are a blessing if you have manual steering too!
One thing I did do was adjust the amount of front brake pressure down a bit. I have had to "panic" stop and the little bit of adjusting I did, did wonders! Let the 10" back tires do some work!
1992 Firebird 355/Six Speed (Soon to be LT1)
1991 RS 350 / 700-R4
1987 Toyota Pickup 383 / 500 + HP 10.963 @ 119.95 Slicks / 11.997 @ 114.23 Radials
http://personal.lig.bellsouth.net/~racer383/
Mark W. Winning is offline
