How large of a tire with a 15" wheel on a 68 - Team Camaro Tech
post #1 of 15 (permalink) Old Dec 26th, 00, 07:48 AM Thread Starter
OK, so everybody wants to know about the low profile tires. I just want to know how much meat i can fit under a 68 camaro with 15" wheels and the fender lip rolled.
jvolk81 is offline
post #2 of 15 (permalink) Old Dec 26th, 00, 09:14 AM
with out fender mod.s,the biggest i can fit are 275/60/15's.8.5"wheel w/ 4.5" b/s.
My '68 Camaro
Doug G.
68 Camaro
406 ci.
post #3 of 15 (permalink) Old Dec 26th, 00, 04:37 PM
I believe with a 15X7" wheel with 4.5" BS, the most you'll get with "no" rub is a 265/60/15. I'm assuming you want the tire to tuck inside the lip.
[This message has been edited by Mike67RS (edited 12-26-2000).]
Mike67RS is offline
post #4 of 15 (permalink) Old Dec 28th, 00, 01:45 PM
275/60/15 on 8"rim w/4.5 bs is no problem.
kevin walsh is offline
post #5 of 15 (permalink) Old Dec 28th, 00, 04:03 PM
Jeremiah
Guest
Posts: n/a
I have also been through this before. On my 68 Camaro I found that on a 8 1/2" weld wheel with 4 1/2" backspacing the 275/50 looked the best in my opinion. The car was lowered the Wheel house opening was even with the top of the tire. The tire did rub from time to time on the inside wheelhouse when turning into a steep drive at angle. The 275/60 was a little to tall looked too much like a truck tire. I think the 275/60 looks great on a lowered 69 though.
good luck.
post #6 of 15 (permalink) Old Dec 30th, 00, 01:03 PM
Tony
I was running a 295/50/15 BFG on a 15x8 Vette ralley wheel on the back and never had a problem.
TONY
67 CAMARO R/S CLONE, 355/turbo 350, 200hp NOS,12 bolt,etc...
idoxlr8 is offline
post #7 of 15 (permalink) Old Dec 31st, 00, 05:21 AM
Randy
rs1968ss's Avatar
What about front tire size?
Cars:
68 RS/SS BB ragtop
63 Nova II ragtop
Club:
Camaro Club of Kansas City
rs1968ss is offline
post #8 of 15 (permalink) Old Dec 31st, 00, 06:01 AM
On front I run a 235/60/15 on a 15x7" wheel (4.5" backspace) with very minimal rub.
http://geocities.com/mike67rs/1.html
Mike67RS is offline
post #9 of 15 (permalink) Old Dec 31st, 00, 08:00 AM
Tony
My fronts are 26-7.5-15's mikey thompson sportsmans on a 15x5 ralley wheel (off of a 65 CAPRICE). With derbie caps (I cut the front's down 3/4 of an inch to keep it from sticking out past the wheel) you have to look real hard to see the big-n-little package. Otherwise it looks like 15x8 ralley's from the side.
idoxlr8 is offline
post #10 of 15 (permalink) Old Jan 1st, 01, 06:01 AM Thread Starter
idoxlr8, did the 295's stick out past the wheel well???????
jvolk81 is offline
post #11 of 15 (permalink) Old Jan 1st, 01, 07:37 AM
Tony
jvolk81,
They where even with the top of the wheel well as far as sticking out. If you give me you email address I'll send you a picture.
TONY
idoxlr8 is offline
post #12 of 15 (permalink) Old Jan 1st, 01, 04:00 PM Thread Starter
idoxlr8
my email address is [email protected]
68 Camaro orig. 396 RS/SS 4spd w/ air.
jvolk81 is offline
post #13 of 15 (permalink) Old Jan 3rd, 01, 02:44 AM
Yep, you can run a 295/50/15 out back with the right offset (I think 4 1/2) on a 15x8 wheel. If you are running fast through a turn, they will roll slightly and rub the inner fender well slightly. I wouldn't try this on a 69 though, the rear wheelwells don't seem to allow enough room. If a 67 or 68 sits too low (mono leaf springs) you will also have some clearence problems.
bowtieusa is offline
post #14 of 15 (permalink) Old Jan 3rd, 01, 02:47 AM
and I forgot to reply, no these tires will not stick out past the wheelwell. They are inside from the top lip of the wheelwell approximately 1inch or more. I run these and 235/60 15s on a 15x7 wheel up front with no clearance problems.
post #15 of 15 (permalink) Old Jan 3rd, 01, 03:55 AM
Cool
I am currently running 215/60R/14s up front and 265/50R/15 out back, no fender mods and lowered 2" all the way around.
68 Corvette Roadster
427/435
4-speed, tri-power
Ralley Red/Tan
Both tops, off-road exhaust
67 Camaro SS 350, 4-speed
Ermine White/Red int, Black Top
67 SS Camaro
67 Camaro RS 350, 4-speed, Marina Blue/Black int.
47,000 orig. mi.
67 RS Camaro
2-67 Camaros is offline
