How does this combo sound guys? - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 15th, 01, 04:11 PM Thread Starter
I need to replace the old Goodyear Eagle ST's that are on the car now. I'm currently running P255/70R15's(rear) and P225/70R15's(front) on what I understand as stock 'Vette 15inch rally's. The front passenger tires rubs a bit on hard cornering on the fender well. You guys think a P235/60R15 would help out my rubbing problems on the front? As it has a smaller diameter and only minimal tread width gains. What do you guys think? I'd like to stick with Goodyear's...unless there's a good reason not to.
The 255's fit fine out back. Of course I wouldn't mind a wider tire with the same diameter...but I can't find any Goodyears.
Any suggestions would be great.
Dan-69rallysport is offline
post #2 of 8 (permalink) Old Jan 15th, 01, 10:26 PM
If your wheels are 15X8's with a 4" BS, I dont think they will work up front. I had problems with the rear outer tire hitting the lower rear fender well on turn in. I went to 15X7 with 4.5" BS on my front. They fit perfect.
http://geocities.com/mike67rs/1.html
Mike67RS is offline
post #3 of 8 (permalink) Old Jan 16th, 01, 02:34 AM
I have 15x8 with 4" bs on my 69, running 235/60/15 and do not get any rub. I have rebuilt the front end though. I am going to get 15x8's with 4.5bs and that will help also.
Jay 69 SS-350
JayBird is offline
post #4 of 8 (permalink) Old Jan 16th, 01, 02:41 AM Thread Starter
Alright. Mike I'm having that exact problem just like you described it with my current combination.
How much backspacing does a stock 'Vette 15inch rim have? How much does it cost to have your rims reworked with more backspacing?
post #5 of 8 (permalink) Old Jan 16th, 01, 08:30 AM
Dan, All the 15X8 Corvette rallys I have seen are 4" backspace. Cant't tell you how much for the work, but it might be cheaper to buy new wheels. I have them on the rear, but went to 15X7's up front. They have a 4.5" BS.
Mike67RS is offline
post #6 of 8 (permalink) Old Jan 16th, 01, 08:33 AM
BTW, you might be able to fit 225/60/15's or 215/60/15's on your Vette wheels if youu really want to keep them. If you have an America's Tire or Discount Tire shop around your house, they will usually test fit without a problem.
[This message has been edited by Mike67RS (edited 01-16-2001).]
Mike67RS is offline
post #7 of 8 (permalink) Old Jan 17th, 01, 02:22 AM
Mike,
How does your ralleys look with the smaller beauty ring on front, compared to the back?
Its much cheaper to buy new rims from summit.
Jay 69 SS-350
JayBird is offline
post #8 of 8 (permalink) Old Jan 17th, 01, 08:26 AM
Jaybird,
When I got the 15X7's up front, I also bought a set of 4 trim rings for the 15X7 wheels.(that's how the repros were sold) The fronts didn't match the rears. Just for kicks I put the new trims rings on the Corvette rally's to see how they would look. I kept them on. The outer portion looks the same. The only difference is about 1/2" less ring inside the wheel. You really can't tell the difference, and it is nice having matching rings.
Mike67RS is offline
