Late model rims on a '69 - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 17th, 01, 05:34 AM Thread Starter
Has anybody installed the 16x8, 5 spoke rims with 245/50R tires from a late model onto a 69 Camaro? Back spacing would be an issue, but how about actual width? My car has a 2" drop in the front and 1.5" in the back. Thanks.
69 Cadmaro is offline
post #2 of 4 (permalink) Old Jan 18th, 01, 02:22 AM
Cadmaro,
By chance, do you have the Hotchkis front and rear leaf springs installed to lower your car? The rims should work, if the rims have a 4 3/4" lug bolt pattern and no more than 4.5" bs.
Jay 69 SS-350
JayBird is offline
post #3 of 4 (permalink) Old Jan 18th, 01, 04:44 AM Thread Starter
Yes, I did install the complete Hotchkis suspension system. I also swapped in a Dana 60 and am running Wilwood discs front and back. The Dana is from a 71 Challenger and is about an inch or so wider on each side, so I know backspacing will be an issue there. I don't have the front clip on yet, so I have no idea if the new rotors require a different backspacing or not.
post #4 of 4 (permalink) Old Jan 18th, 01, 03:46 PM
Cadmaro,
How do like the Hotchkis kit? Does it level the car nicely? I have the front springs installed and Im waiting on the leafs.
I dont know if the rims will work with a dana rear. Being that it is wider, I would say that you could run more backspacing, but dont know for sure.
Jay 69 SS-350
JayBird is offline
