tires and wheels for my '69 - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 15th, 01, 05:23 PM Thread Starter
i just purchased a 1969 camaro and i am planing on trying out the pro touring look. i have read many articles on tire and wheel sizes but it seems no one is sure whats going to fit. i am planning on going with hotchkis 2" lowering coils and 1 1/2" lowering springs in the rear. my shocks have already been moved inwards on the 10" rearend. will a 275/40/17 fit in the back and whats the largest size i can fit in the front. thanx for everyones help!
vtec is offline
post #2 of 7 (permalink) Old Feb 16th, 01, 02:16 AM
Go back on this site they were talking about this. One guy had some pic's too. Good luck
69 RS Z/28 96IMAPLA SS 82 C10 SWB 300HP 350
Tim Meredith is offline
post #3 of 7 (permalink) Old Feb 18th, 01, 08:18 AM
I have a '68 with an unmodified rear, and I am running 16x8 rims with 255/50/ZR16 rubber. There are no fit probs. On the front I have 16x7 inch rims with 225 rubber. I don't know how much bigger you could go in front, but if you moved the rear shocks, I am sure you could go bigger than the 255.
boodlefoof is offline
post #4 of 7 (permalink) Old Feb 21st, 01, 04:39 PM
I'm running 17x7 and 17x8 TT2's with BFG Comp T/A 245/45/17 and 255/45/17 tires on my car. You can run up to 17x9-1/2" with 275/45/17 tires on the rear. Keep in mind that the available inside space is right about 11-3/4" and the section width of a 275/45/17 is 11" so if the tire is centered you'll have 3/8" each side. If the car is lowered with lowering blocks in the rear the lower shock mounts interfere with the wheel - if your's are moved in and/or you are usind lowered springs you should be OK.
'69 400SB, Richmond 5-speed
www.geocities.com/sdenning1
RockyMtnRacer is offline
post #5 of 7 (permalink) Old Feb 22nd, 01, 03:01 AM
boodlefoof, do you have a photo or two of your setup? I assume the 16x8 have 4.5 backspace? Really interested in filling the wheel wells rather than the tall skinny look. Sorry for the sidetrack VTEC.
Carkrazy is offline
post #6 of 7 (permalink) Old Feb 24th, 01, 05:14 PM
RockyMtnRacer
Those wheels look awesome on your car. What offset are you running on the front and rear? Do you have any clearance problems when turning or over bumps? If you do, with what part of the car?
my69gofast is offline
post #7 of 7 (permalink) Old Feb 24th, 01, 07:28 PM
my69 - I am running 4" backspacing front and rear with no rubbing at all. However, I do have a 9" rear and I think the width is slightly different from a Chevy rear. I also trimmed the lip on the rear a bit, although it was really to clean up some rough edges and a little insurance.
