What fits what - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 16th, 01, 11:56 PM Thread Starter
Alright I got 15x8 rally's with 215/65/r15 on all fours and the fronts scrape my fenders pretty bad when I turn since I replaced the front coils.
What size tire would I need or should I just go with a 15x7?
If I do go with a 15x7 what size tire would I need so I don't scrape em?
Also what the heck is backspacing.
67stock is offline
post #2 of 5 (permalink) Old Feb 17th, 01, 03:06 AM
I've got 15x7's Ralleys, 4 1/2 backspacing, with 235/60/15's on the front. New BB coils springs and shocks, no hint of rubbing. This has been discussed before at length, and I believe the consensus was the 235 would be the widest that would fit on the front without rubbing. If you have any doubts, the 225's will fit for sure......KZ
John D. Smith
69' SS/396
www.geocities.com/kz1000ltd
kz1000ltd is offline
post #3 of 5 (permalink) Old Feb 17th, 01, 06:03 AM
The 15X8's have a 4" backspace, that is why the outside of the tires rub on turn in. A 15X7 with 4.5" B.S. is what you need.
http://geocities.com/mike67rs/1.html
Mike67RS is offline
post #4 of 5 (permalink) Old Feb 17th, 01, 10:28 AM Thread Starter
So is backspacing how tall the tire is?
67stock is offline
post #5 of 5 (permalink) Old Feb 18th, 01, 06:49 AM
Backspacing is measured from the inside wheel hub (where your wheel bolt on) to the backside wheel lip. A 4.5" backspace will be set further into the wheelwell than a 4" backspace. A 15X8" wheel with 4" BS will actually stick out 1" further than a 15X7 with 4.5" BS. (1/2" for wheel width and 1/2" for BS)
Mike67RS is offline
