Wheel Spacers? - Team Camaro Tech
post #1 of 2 (permalink) Old Feb 20th, 01, 08:10 AM Thread Starter
I have a 1969 Camaro Convertible and want to put the AR TT 17" rims w/245 40 in front and 275 40 in the rear. I have read that I need a 5" back spacer for the rear and a 4 3/4" spacer for the front.
Will this push my tires outside of the wheel well? Does the use of spacers compromise the strength from the wheel to the axel?
jrager is offline
post #2 of 2 (permalink) Old Feb 21st, 01, 06:58 AM
What you're referring to is "Back Spacing" and it's the dimension from the inner wheel lip to the back of the mounting pad. Stock for a Chevy wheel is 4" of b.s. Those dimensions you listed will pull in the wheels more, so you can fit a bigger wheel/tire combo. I've heard that the max. b.s on a stock suspension is 5" any more you'll be rubbing on the shocks, etc. I would go 4 3/4 max. and you should be safe.
As for the wheel width on a '69 I would think about 8" is max. up front on a stock app. And unless you plan to do some wheel lip trimming out back, no more than a 8.5"
Some '69 owners can probably give you better info on widths.
JD
[This message has been edited by John Doyle (edited 02-21-2001).]
John Doyle is offline
