69 with 17" wheels - Team Camaro Tech
post #1 of 10 (permalink) Old Mar 14th, 01, 02:24 PM Thread Starter
I know ya'll are sick of this question but please help. I would like to use 17"x8" up front and 17"x9" or 9.5" in the back if possible without modifing. I will be using hotchkis springs 2" lower front and 1.5" lower rear. Will this work? What backspacing and what size tires can I use? Thanks for the help.
L.Garner69conv is offline
post #2 of 10 (permalink) Old Mar 14th, 01, 03:33 PM
My brother in law had 17" Centerline Sabers on his 69. I think he had 8" up front with 245/45's and 9.5's on the rear with 245/45's. The backspacing is 5.5 on the rear don't know about the front. His car was lowered about the same amount. A set of 17"s will sure make it look good. As for me, I can't even begin to tell you how glad I will be when my 67 is ready for rims and tires.
blancefitz is offline
post #3 of 10 (permalink) Old Mar 14th, 01, 03:35 PM
275/40's on rear. Sorry.
post #4 of 10 (permalink) Old Mar 14th, 01, 04:59 PM
Thumbs up
first of all let me say that i now have the same suspension components you are using( hotchkis front and rear). i have done a lot of research and a 245/40-17 on a 17x8" in front with 4.5" of backspacing will fit! they are now on my car!
i havent done the rear yet but i am sure that 275/40-17 on a 9.5" rim will fit, only if you move the rear shocks completely inside of the springs and do some body work to the fender well inside and out. a 5" to 5.5" backspacing will be needed to clear everything. i am going to go with the 5.5" of backspacing and then use a 1/4 " spacer on the hub to make it all work. i think i may even be able to squeeze a 285/40-17 in there.
my project funds are gone for now but in the future i will let everyone know what exactly fit. good luck!
sorry you will have to do a little modifying to get this killer look!
vtec is offline
post #5 of 10 (permalink) Old Mar 15th, 01, 02:46 AM
Do a search, you'll find alot of information on the subject. Moving the spring inboard will not provide any additional clearance when using 17" wheels, the limiting factor is the inner fender.
68 468 700R4, and here it is;
mutert23
MarkM is offline
post #6 of 10 (permalink) Old Mar 15th, 01, 04:07 AM
Mark is right. Also, the inner wheelwell dimension on a '69 is 11-3/4". The section width of a 275/45/17 is 11". That leaves a mere 3/8" per side assuming the tire is perfectly centered. If the 285 is any wider - and of course it is - you may be able to wedge it in but it will absolutely rub.
'69 400SB, Richmond 5-speed
www.geocities.com/sdenning1
RockyMtnRacer is offline
post #7 of 10 (permalink) Old Mar 15th, 01, 08:21 AM Thread Starter
Thanks for the help. Scott is the 11-3/4" wheelwell the same on convertibles? If I went 17x7 and 17x8 what is the biggest tires I could use with no modifications? Thanks.
post #8 of 10 (permalink) Old Mar 16th, 01, 04:17 AM
I don't know why convertibles would be different - however, every car can be different so I'd measure yours first.
I'm running 245/45/17's on 17x7 wheels with a 4" BS on the front of my car and they fit fine. I don't think you can go bigger without rubbing.
In the rear, the consensus here seems to be that 275/45/17's will fit if they're centered. Some guys report a little rub going into a driveway or something similar that twists the car but they seem to fit if they're centered and the lip is trimmed and flattened. IMO, a 265/45/17 would be a great fit but I haven't found one yet!
post #9 of 10 (permalink) Old Mar 31st, 01, 08:43 PM
Jeremiah
Guest
Posts: n/a
I have been through this before on my wifes car. The 17/8 with a 4 1/2 backspacing will fit the front. The rear is best with a 5" backspacing. Any more and you will rub on the inside when turning into a driveway or any twisting of the rear. The 275/40 is the widest tire you can fit without tearing your car up. The tire size on the front is 235/45. I put 17/7 on the front of my car with a 4 1/2 backspacing and 17/8s on the rear with 4 5/8 backspacing. In my oppinion they look meaner than the larger ones. And you have more tire choices. One thing people forget when they get the huge wheels is you are limited to a short profile tire because of sidewall clearances. In my oppinion the 275/40 is too short and does not fill the wheel well at all. But thats just my oppinion.
post #10 of 10 (permalink) Old Apr 1st, 01, 03:34 PM Thread Starter
Jeremiah thanks fo the response. What year is your wife's car and what size tires are you using? Thanks again for the help.
