Running slicks with out tubbing...or rubbing - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 19th, 01, 06:10 AM Thread Starter
I have a 69 Camaro RS that is a cruiser as well as a weekend warrior and I have the origional 15x8 rally wheels. I want to get a set of slicks but don't know what size to buy, that will fit in the wheel wells. Any one know ???
69CamaroRacer is offline
post #2 of 7 (permalink) Old Mar 19th, 01, 06:36 AM
DjD
DjD's Avatar
Check your wheel size. Origional is not 15x8 and if you bought 15" slicks and you really have 14" wheels you won't be happy! The Z/28 is the only car that came with 15" wheels If my memory is correct. The Z would have 15x6 or 15x7 (not sure) and all other 1st gens got 14".
I'm not 100% but the point is they get switched so verify before you buy!! I was told my ralleys were 15x8 with 4.5 back spacing and after checking I found them to be 15x7 with 4" BS...
...Dennis
'69 RS Convertible w/SS trim
'96 Z28SS #1679 of 2410
"The Club"
DjD is offline
post #3 of 7 (permalink) Old Mar 19th, 01, 02:55 PM
Smile
What DjD is trying to tell you is to tell us what your wheel size actually is then we can probably come up with something for you that somebody has tried and knows fits!!
15" x ??", ??" backspace is what we need to know... pdq67
post #4 of 7 (permalink) Old Mar 19th, 01, 09:37 PM Thread Starter
Well this is the problem I have no Idea about the back spacing on my rims ... to tell you the truth I know nothing about back spacing it's kinda mistry to me... I do know that the rims are 15x7's any info you give will be helpful. thanks
post #5 of 7 (permalink) Old Mar 21st, 01, 12:24 PM
Talking
Checking your backspacing is easy just pull
the wheel off lay it down with the backside
facing up take a straight edge lay it across
the rim only then measure from the area of the rim that meets the drum when mounted to the bottom of the straight edge this is the amount of backspace the rims you have currently have. Hope this helps you out some.
Jeff
RODKNOCKER is offline
post #6 of 7 (permalink) Old Mar 22nd, 01, 10:03 AM
You could look into the drag radials in Summit's catalog. They have some fairly stock sizes.
boodlefoof is offline
post #7 of 7 (permalink) Old Mar 23rd, 01, 06:03 AM
Tim
What is your gear ratio?
YOu may want a taller or shorter slick depending on your ratio.
I would go with a set of 26"x8.5"x15 if you have a hight gear. that way you can take advantage of the shorter tire to help out your lack of good gears.
Tim
ratchetmaster
1968 RS SS 350
1968 RS pro street project
1972 454 ElCamino
1999 Firebird WS-6 T/A
moderator http://www.gmforums.com
[This message has been edited by ratchetmaster (edited 03-23-2001).]
ratchetmaster is offline
