Rolling the lip - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 27th, 01, 10:40 AM Thread Starter
Hey guys,
What's the best method for rolling the fenders on my '69? Anyone have any experience in doing this?
'69 Restification
JonT is offline
post #2 of 4 (permalink) Old Mar 27th, 01, 05:11 PM
ive had to do it on my car and a couple of 5.0's. It seemed to work best with some tight fitting tires and a basball bat. Just insert it the crease and roll the car forward. then do the same thing backwards. it takes a long time to get it to start creasing right .lots of back and forth's
68'Pro-touring 5.0 Killer
Camaro6666 is offline
post #3 of 4 (permalink) Old Mar 29th, 01, 05:43 AM
I've done the bat method before. IMO it works best if you have a couple guys stand in the trunk. Start with one or two and add until you get the lip rolled right. You really need the extra weight to get the right amount of force. Most recently, I had a body shop trim mine out a bit and then hammer them upward a little. That worked well too.
'69 400SB, Richmond 5-speed
www.geocities.com/sdenning1
RockyMtnRacer is offline
post #4 of 4 (permalink) Old Mar 29th, 01, 01:56 PM
I would be hesitant abouit the baseball bat trick. If something requires that much force, something else may happen that wasn't expected.
69er
69 Camaro 454
71 Nova 454
If your not living on the edge then your taking up too much space
69er is offline
