16" rallye? - Team Camaro Tech
post #1 of 8 (permalink) Old May 12th, 03, 05:04 PM Thread Starter
does anyone know if there is a 16" steel rallye wheel available? I know there are billet versions available but they're a little expensive, as I'm doing it to raise the height of my car so it's useable at a new house I'll be moving into at the end of the month.
lil_beast_67 is offline
post #2 of 8 (permalink) Old May 12th, 03, 08:21 PM
Look up Wheel Vintiques
67RS-zz4 w/ trickflow heads 276hr cam air gap 780 Pro Systems TexRacing 4spd AGR steering SCAT procars 12 bolt eaton posi 3.73's SSBC all around, TT2's Dakota Digital Painless DSE hinges
Mike's67 is offline
post #3 of 8 (permalink) Old May 12th, 03, 08:56 PM
Also
www.stocktonwheel.com
89 C4 Coupe/Z51/ZF6/J55
Sold the 69
TOMS69 is offline
post #4 of 8 (permalink) Old May 13th, 03, 08:46 AM
Nick
Check my Signature under my car they 17x8x5 Nick
67 rs/ss 350 original eng,700r4, a/c, tilt, deluxe int,strato bench,Ca.emission,front disk,am/fm,floor clock,17" W/V Ralleys,Toyo T1S 255/40/17, 245/40/17
MRCOOL_RSSS350 is offline
post #5 of 8 (permalink) Old May 13th, 03, 11:50 AM
Check out Newstalgia Wheels. They've got steel in 16" & 17"
Randy S is offline
post #6 of 8 (permalink) Old May 14th, 03, 05:48 AM
Gene
I bought the Wheel Vintiques - 16x8 with 4.5 inch backspacing. They were around $100 each several years ago. Noit sure of pricing now. Nice wheels, except that their chrome doesn't last. Two of mine started rusting about a year after I put them on the car.
Stockton Wheel also makes a beauty ring for 16-inch ralleys. They are $150 a set.
1969 Camaro - Intense Blue Pearlcoat/white (Baldwin-Motion paint scheme), stock 6.2 liter L92 with VVT, LS3 intake, Doug's Headers; Tremec TKO, 3.73 12-bolt posi.
gheatly is offline
post #7 of 8 (permalink) Old May 14th, 03, 11:28 AM
Will Stockton Wheels 16 inchers accept a standard 15 inchers Derby cap (69 rally wheel center)?
thanks
ps whats the widest 16 inch tire a 69 Camaro will accept, I just happen to have a set of 255/50x16 sitting in garage
billyd is offline
post #8 of 8 (permalink) Old May 14th, 03, 11:48 AM
Gene
You could fit the 255s on the back with the proper wheel. The 255s are not too large in diameter for the front, but they would probably rub on the frame when you turn the wheels to the locks. You could offset the front wheels further out to avoid hitting the frame, but it might not look good.
gheatly is offline
