White raised letters. How do you clean them? - Team Camaro Tech
post #1 of 12 (permalink) Old May 16th, 03, 01:07 PM Thread Starter
I have B F Goodrich T/A Radial tires with the white raised letters. What is the best way to get them white again. Some of the letters have turned brown. I am careful now not to get tire shine products on them when I shine my tires. I have tried window cleaner, tire/wheel cleaner and tonight I am using a Q-Tip with bleach. Any ideas????????
supv26 is offline
post #2 of 12 (permalink) Old May 16th, 03, 02:08 PM
Westley's bleech-white. Spray on, hose off and that's it. I usualy scrub a little but if you keep them up, you will have less work to do at wash time. You might not want to let it dry on any painted surfaces as it is fairly strong. Works great.
-Mark.
stingr69 is offline
post #3 of 12 (permalink) Old May 16th, 03, 02:18 PM
DjD
DjD's Avatar
Angry
SOS pad!! dip it in some water scrub the whole tire and rince!!
...Dennis
DjD is offline
post #4 of 12 (permalink) Old May 16th, 03, 04:46 PM Thread Starter
Angry
Thanks for the tips, it worked!! I also went into my gun shop and got a little gun scrubber brush. I dipped it in the bleach and scrubbed away. WOW that sure worked!!
supv26 is offline
post #5 of 12 (permalink) Old May 16th, 03, 05:46 PM
I usually use Soft Scrub and a scrub brush. Cleans them up very nicely and easier to scrub using the scrub brush compared to an SOS pad.
brotherdale is offline
post #6 of 12 (permalink) Old May 16th, 03, 06:00 PM
Tim
Send a message via AIM to sixtsevnssrs
Westleys bleach white is great stuff. I use a little floor brush. You know the type, long with a handle. If you run out of westleys, the wifes fantastic is pretty good too. I also use the fantastic and an old t-shirt on my suspension pieces before a show. Cleans up the frame and lower control arms, steering parts. Good tip!
Oh...how about cast aluminum wheel cleaner for your aluminum intake, that works pretty good too, if you need to scrub it a little use a toilet brush.
Tim
sixtsevnssrs is offline
post #7 of 12 (permalink) Old May 17th, 03, 10:22 AM
Gary
MangeMD's Avatar
Angry
Westley's works nice, so does Simple green. I just use a small brush and spray it off.
MangeMD is offline
post #8 of 12 (permalink) Old May 18th, 03, 05:06 PM
Westleys works good for me. If you wear white sneakers. Works great on them too.
Fast67 is offline
post #9 of 12 (permalink) Old May 27th, 03, 05:46 AM
after I wash the car,truck or what ever ,I spray
castrol super clean on al the tires,then go back with a my wash soft brush dipped in the wash water and go around afew times and hose off.
leaves the tires nice dull clean black,and letters nice and white.
IO don't like my tires tobe shiny.
"Drive it like you stole it"
2000 SS camaro daily driver(wifes)
Oncea3Fan is offline
post #10 of 12 (permalink) Old May 27th, 03, 02:35 PM
I have always just used alot of elbow greese and a scrub brush.
68 Camaro~LSx ~all motor
post #11 of 12 (permalink) Old May 27th, 03, 04:51 PM
Call me Funk
Send a message via AIM to CFunK
Ditto, the Castrol is great stuff on tires AND hte raised white letters.
-Funk
CFunK is offline
post #12 of 12 (permalink) Old May 27th, 03, 10:30 PM
Wow a little residual breakfree on the brush worked wonders [img]graemlins/thumbsup.gif[/img]
Snatchin'gears is offline
