M/T ET tire patch - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 11th, 03, 03:05 PM Thread Starter
Has anyone ever had to patch a nail hole in thier M/T ET streets, was it just a normal patch like any other for a radial tire.
67 camaro 462 BB 9.6 CR Compcams 314HR 252 @ 50 612 lift, Port+Polish Oval port 2.19 1.88, Edelbrock RPM intake, 850 Holley DP, 3" exhaust, turbo 400 TCI 4000 stall, Dana 60 4.10 posi, 315/60/15 BFG M/T drag Radials, 3650lbs. w/driver. [email protected]
CanCamaro is offline
post #2 of 4 (permalink) Old Jun 11th, 03, 06:24 PM Thread Starter
No flats
Dino
post #3 of 4 (permalink) Old Jun 12th, 03, 12:32 AM
Sean
i may be wrong here, but i thought et streets were a tube only, or tube highly reccomended tire. apparently you are running them w/o though, so it obviously works. i would be concerened about patching one due to the highly flexible nature of the tire. i think my solution would be to just get a couple of thier tubes for them, and be done with it. seems like the best/safest solution to me. good luck, hope that helps
Sean
Franklin D. Roosevelt
68rs406 is offline
post #4 of 4 (permalink) Old Jun 13th, 03, 02:01 AM
choptop's Avatar
If you're running the tires at the track I would definitely not run a patched tire! I don't think it's safe with the abuse tires take at the track. If they are tube type tires get a tube as suggested or get new tires and save the good one as a spare!
choptop is offline
